Edge molding for hatch?
Postby Home Away... » Wed Mar 23, 2011 3:52 pm
Do you normally use the same edge molding for the hatch that you use for the main body of the TD?
Home Away...
Postby madjack » Wed Mar 23, 2011 4:12 pm
...if you can...I used standard RV insert corner molding for all the outer edges...it is available from RV supply house(usually painted) and I believe Grant at Lil Bear and the folks at So-Cal Tds sell it as well both with mill finish................
madjack 8)
Postby jtsarby » Wed Mar 23, 2011 5:21 pm
I found stair tread edge guard at Lowe's that I am going to use. It comes from 3-12 feet long and is 1 1/4" x 1 1/4 angle. It also comes in mill, pewter, and brass finish. Best of all it is only 10.95 for a twelve foot long piece. I am building a weekender so I don't have any curves, only angles. I don't know how well it would bend.
jtsarby
Images: 15
Postby CARS » Wed Mar 23, 2011 9:00 pm
jtsarby wrote:I found stair tread edge guard at Lowe's that I am going to use. It comes from 3-12 feet long and is 1 1/4" x 1 1/4 angle. It also comes in mill, pewter, and brass finish. Best of all it is only 10.95 for a twelve foot long piece. I am building a weekender so I don't have any curves, only angles. I don't know how well it would bend.
I wont bend well at all, but will work for you though.
Let me edit that: It will bend, but will kink and not form well
Chris'
Autobody
Restoration
Service
CARS
Postby Bucko6 » Fri Mar 25, 2011 7:21 pm
I used a snap on door edge guard from an auto parts store.
Bucko6
