Eagle , you planning on some Artwork ???
I painted some 4X8 signs for a local Rock Music store , used artist acrylic paints and they lasted 10 years with nothing on them ... Some good UV varnish would have probably protected them better , but they were outside,facing the broiling western sun , and right next to an expressway , with all those fumes , etc... A testament to acrylic paint ...
... and by then the music store was out of business anyway ...
Dink, a boat is always a good idea around here...
Droid , 1" foam sheet is pretty light I think it's like 2 lbs/cu.ft .... plywood is like 57 lb. per cu. ft. Big Difference ..
The foam only has minimal strength , but once skinned on both sides is surprisingly Strong !!! The skin is the secret !!!
Now I got a sheet of ply for the floor , 3/4" Pine so HEAVY , I can't pick it up...
