1. I quess the power cord comes in thru the right side then goes to the appropriate bars. There is a ground bar on the back I think for the plain copper wire(this says to ground to the frame). Does this look and sound correct?
2. 12v I used white and black 14awg stranded wire for my 12volt.
This unit has some screw connectors below the fuse holders. For which colored wire (white or black) and what do I do with the other colored wire that I don't put in the screws. Do I need a ground bar or something? Please explain.
3. The last fuse slot says it's for battery charger hookup.
What size wire do I use(if I have a battery hooked up) and wouldn't there be two wires coming from the battery.Where doews the other one go?
Please explain, be datailed and simple.
Thank you all so much.
Keith
![Hammer :hammer:](./images/smilies/Hammer4.gif)
