varnish, then apply aluminum???????
Postby seahorse » Mon Feb 06, 2006 2:02 pm
I'm ready to skin trailer with aluminum. Should plywood be spar varnished before applying aluminum? Will henry's 663 adhere to varnish, if it is to be applied first? :roll:
seahorse
Images: 39
varnish then apply . . . .
Postby rooster » Mon Feb 06, 2006 2:55 pm
seahorse, I varathaned my tear with three coats and applied the aluminum using Henrys 663, and I had two friend help me. As for varnish I don't have a clue. There are those that build boats canoes and such that can answer your question.
Jim, :thinking:
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby seahorse » Mon Feb 06, 2006 4:19 pm
Thanks Rooster, I didn't know for sure if sealing was nessessary if aluminum is being used........ :thinking: but evidently it is. I'll try varathane instead since I don"t know about the spar varnish either.......Thanks again!........Rob
seahorse
Images: 39
Postby mikeschn » Mon Feb 06, 2006 5:13 pm
I didn't seal my plywood before installing the aluminum on my first teardrop. I suspect it's just a matter of time before the water gets in and it starts to rot.
If I were ever to do another aluminum teardrop, I would fully waterproof before floating the aluminum over it. I would probably uses CPES. There's some info about CPES here: http://www.mikenchell.com/weekender/skinning.html
Postby seahorse » Mon Feb 06, 2006 6:31 pm
Thanks Mike, CPES sounds like a great product, BUT....... :shock: the price is more than my budget will allow .........Rob
seahorse
Images: 39
Postby mikeschn » Mon Feb 06, 2006 6:34 pm
seahorse wrote:Thanks Mike, CPES sounds like a great product, BUT....... :shock: the price is more than my budget will allow .........Rob
Only one question for you... How long do you want your teardrop to last?
Postby seahorse » Mon Feb 06, 2006 7:11 pm
Mike , your TWISTING my arm.......... :o My question for you is........How much CPES to cover 125 sq. feet?
seahorse
Images: 39
Postby toypusher » Mon Feb 06, 2006 7:18 pm
Not to contradict anyone and no offense meant to anyone. But, you really should not need to seal the plywood under the AL if all is dry first and you seal all the seams properly. Yes, some water or condensation may get in, but to do any real damage will take a long, long time. Years!
Just my opinion! Obviously sealing the plywood will not harm anything.
:D
toypusher
Images: 324
Postby mikeschn » Mon Feb 06, 2006 7:35 pm
seahorse wrote:Mike , your TWISTING my arm.......... :o My question for you is........How much CPES to cover 125 sq. feet?
Seahorse,
I don't mean to twist your arm...
For a different perspective, let go over to Camp-Inn and see what they do..
Ah, here's the link... http://home.centurytel.net/edevold/faq.htm#q3aaa
I don't have a photo of the campinn in the spray booth. Maybe Pateardropper or someone else does...
But the point is, leaks do happen. Insurance is cheap...
Mike....
P.S. To answer your question about CPES... probably 1 or 2 quarts...
Postby seahorse » Mon Feb 06, 2006 7:44 pm
I guess some sort of sealing is recomended. I will purchase 1/2 gal CPES and seal edges first........ then use remaining to cover what I can.....thanks I didn't know which way to turn .
seahorse
Images: 39
Postby mikeschn » Mon Feb 06, 2006 7:52 pm
That sounds like a plan to me...
If you are not comfortable with the cost of CPES, maybe you need to look at varnish...
Steve F... or anyone else familar with epoxy... your thoughts?
Postby seahorse » Mon Feb 06, 2006 8:05 pm
Thanks, I thought 2 gallons were needed :shock: but I see thats not the case........ $50.00 of insurance is not much in the long haul.......Thanks all for your input. :)
seahorse
Images: 39
Postby Steve Frederick » Mon Feb 06, 2006 8:08 pm
I'm currently building a custom project for a customer. She wants an aluminum roof. I intend to apply a sealing coat of epoxy. Most will agree that the adhesive under the aluminum will fail in the heat of the sun, so the application is not to help adhesion, rather,I'll apply the epoxy just as an insurance policy!
I always have the stuff around the shop..So I'll do it. I'm sure that if moisture gets under the skin, it won't rot the wood.
I don't know about the cost comparerd to CPES, Raka marine epoxy is about $50 for plenty to do a roof!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby schreimaster » Tue Feb 07, 2006 9:16 am
I'm getting ready to skin mine, thinking about doing it this weekend. I was thinking the adhesive applied would be seal the plywood and there would not be a need to coat it with anything else :roll: . But from what I've been reading here I may be off track.
Let me know your thoughts.
Lifes not a problem to be solved, but an adventure to be lived!
schreimaster
Images: 86
Postby schreimaster » Tue Feb 07, 2006 9:21 am
And any other tips on skinning this teardrop woul be of great help.
schreimaster
Images: 86
