it begins
it begins
Postby UK-Brian » Sun Apr 03, 2011 10:25 pm
ok here's what I have to start with. a early 70's model pop-up it's a 6x12 box. it's gonna be bigger than what I was planning. can a camry handle it if I stay really lite? manual says towing capacity is 2000#. I will also be adding a trans cooler,will this be ok?
In the coal fields of Kentucky and I bleed WILDCAT BLUE!!!!!!!!!!!!!!!!
GO CATS!!
UK-Brian
Images: 22
Postby doug hodder » Sun Apr 03, 2011 10:29 pm
You might try this link for pic help....Check what the towing capacity is for you vehicle and then design/build accordingly. Welcome aboard! Doug
http://www.mikenchell.com/pichelp.html
Postby CliffinGA » Sun Apr 03, 2011 10:52 pm
Welcome Brian, towing capacity varies for a camry, depending on the year. 2007- 2010 all show 1000lbs for the regular camry and o for the camry hybrid and solara.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby Miriam C. » Sun Apr 03, 2011 11:17 pm
:o You might seriously go down and have the trailer frame weighed before you start! Mine is pretty heavy and not that big.
After that go for it :twisted: and don't forget :pictures: :pictures: :pictures: Image
btw, you might be able to cut the frame down. ;)
Postby Amrva » Mon Apr 04, 2011 6:36 pm
I just tore one of those down to the frame yesterday, though mines only 6'6"x9'. It took me most of the day but I was trying to salvage some parts so I wasn't rushing too much.
The hardest part was getting the old plywood off the frame because I couldn't find all the screw heads hiding under the glued down vinyl flooring. I resorted to setting a circular saw to the depth of the plywood and making cuts all across it so I could rip it free from the frame in smaller pieces.
Also, if your frame is anything like mine it should be VERY light, I don't think mine weighs more than 200 pounds as it is very light guage metal.
Anthony
Amrva
Postby Roly Nelson » Thu Apr 07, 2011 8:54 pm
My 4 banger, '02 Camry has 140,000 miles on it, with somewhere around 25,000 pulling my 8 ft woody teardrop. No trans-cooler, but keep it serviced at suggested intervals. I shift down out of overdrive when on mountain grades and cruise right along with the truckers on the interstates. Works for me. Good luck on your build, remember, pics, pics, pics.
8) :thumbsup: Roly ~~
Roly Nelson
L'il Ol' Woody Builder
Postby Wolffarmer » Sun Apr 10, 2011 2:39 am
I pull my 1100 lbs TD that is a bit higher than most with a 2000 Suzuki Vitara with a 2000cc motor and auto tranny.
Like Rolly says, service the tranny, use top quality oil and slow the heck down and enjoy the trip. I feel that people who put an oil cooler in their transmission so they can drive just as fast as before are still going to have problems.
Randy
Still grumpy after all these years
Wolffarmer
Images: 309
Postby UK-Brian » Tue Apr 19, 2011 8:49 pm
here is some progress. welded some back together this evening, hope to get more done tomorrow. also picked up my plywood, insolation, and will be ordering the epoxy soon. narrowed by 1' and shortened from 12' to 10'.
thanks, Brian
GO CATS!!
UK-Brian
Images: 22
