notned wrote:My axle has a bend in it. We've been running it. The only noticeable effect is a little tire wear. We've discussed the idea of a chain and a jack to straighten it out. We also talked about pulling the axle which I think that I'd like to avoid.
This trailer was built as off-road, so it's possible that there was one incident with a prior owner which wouldn't be repeated. Off-road isn't our thing.
We think that the axle is 1-1/2" pipe. Leaf springs are involved. The bend is on one side where the hanger/springs are.
You may be able to tell that I barely understand what I'm typing so all ideas are welcome
I've got to get this in here, a friend helped me with the wheel bearing job. So that's done, I'm feeling good about that.
notned wrote:
I tried to take a picture underneath but the lighting wasn't good.
Yota Bill wrote:the problem with that way is that it will pull on both ends, and could bend the other end first...alignment or frame shops could do it, but they have systems to measure it, and ways of attaching it to a frame rack to pull only where they need to, instead of both ends
John Palmer wrote:Yota Bill wrote:the problem with that way is that it will pull on both ends, and could bend the other end first...alignment or frame shops could do it, but they have systems to measure it, and ways of attaching it to a frame rack to pull only where they need to, instead of both ends
Bill, you can easiy direct "the pull" by where you place the jack under the axle.
doug hodder wrote:More important is aligning the axle ends to the coupler...
