3822sean wrote:belt sander on the face of lauan sounds scary
jtsarby wrote:It is the texture. I am going for a smooth finish. The lauan has an almost raised grain finish. I used my orbital sander on one small spot and it took the first layer off and revealed a smooth layer underneath. Thanks for the advice on the belt sander. A friend suggested a skim coat of bondo. I dont like that idea and it sounds like a lot of work. Should I prime first or use the Aluthane epoxy first?
jtsarby wrote:Thanks for the info. Should I prime first or seal first?
