S. Heisley wrote:Mike,
Did you decide not to add the red or teal?
Cliffmeister2000 wrote:Love the diamond plate!
Mike, did you use butyl tape, silicone sealer, or what to waterproof the vents and fittings?
myoung wrote:Cliffmeister2000 wrote:Love the diamond plate!
I only used tape on the windows. The trim has adhesive caulk too. All the vents and other fittings fit very flush and tight.
pete42 wrote:Mike Young said"Oops. Strange things are happening so it is time to call Gerald for a little circuit sleuthing. For some inexplicable reason, Dodge doesn't follow the conventional arrangement of connections for the 7-pin plug. The right turn signal and the tail lights wires had to be swapped."
the Receptacle on the Dodge was not wired like a "normal" 7 pin?
did you correct the Receptacle on the Dodge or the plug on the trailer?
I'm thinking if you changed the plug when and if you ever need to pull your trailer with another truck or car the wiring will be wrong.
just a thought, I have so few anymore.
pete
oh yea very nice build.
S. Heisley wrote:Mike, the interior looks nice and very easy-care. I love your windows.![]()
