Loader wrote:Which battery would be best for use in Teardrops?
I have done some searching, however thought I'd ask. I have found "use the biggest marine available", Seen Optima "Blue Tops", etc. Just looking for thoughts and opinions.
I plan to install a single battery and use the Deltran tender when shore power is availble.
Thanks!
madjack wrote:Coop, that is good to hear...I really like the D51 for it's small size(only 5"thick) and lightweight(26#s)...........
goldcoop wrote:I camp in some pretty remote areas of central & northern PA mostly, LOTS of bumpy, rutted, dirt roads...
Coop
goldcoop wrote:Tom-
My biggest trouble with our weeks vaca w/o hookup was my teenage daughter!
Just had to drill her about turning lights, fan, etc. OFF. The power is finite and its not like being at home!![]()
I think if you are conservative, keep your eye on the volt meter, you'll be fine with your set up!
I did notice a outlet in the shower house just in case!:roll:
goldcoop wrote:madjack wrote:Coop, that is good to hear...I really like the D51 for it's small size(only 5"thick) and lightweight(26#s)...........
Well CRAP!
My Optima is the D31 (BIG, Heavy Mutha)!
Sorry!
I made my decision for this battery before I knew this board existed!
Would I do it again?
YES!
Two things (hype or not) sold me: the lack of outgassing and it's vibration resistance.
I'm happy so far, TIME will tell the tale!
Cheers,
Coop
emiller wrote::thumbsup: I don't have the article from trailer life that did an a piece on this subject anymore, but I remember that the lifeline battery out performed all others. I also remember it was a bit pricey also.
