got my new timer switch installed for the fan in our 'guest' bathroom this morning and we just got home from dinner at the inlaws.
Should mow, but not going to for now!
High Desert wrote:so I took a different route home the other day. Driving down a street a see a big mailbox with the name painted on it in big letters. As i read it there was suddenly a Twilight Zone moment; "Fenlason", right there in broad daylight....![]()
Who'd a thunk it? I'd never even heard that name until I "met" glenn![]()
Fenlason wrote:High Desert wrote:so I took a different route home the other day. Driving down a street a see a big mailbox with the name painted on it in big letters. As i read it there was suddenly a Twilight Zone moment; "Fenlason", right there in broad daylight....![]()
I know way back.. there were some of us that went to the mid-west...
Hi Shaun... how's it hangin...
High Desert wrote:Fenlason wrote:High Desert wrote:so I took a different route home the other day. Driving down a street a see a big mailbox with the name painted on it in big letters. As i read it there was suddenly a Twilight Zone moment; "Fenlason", right there in broad daylight....![]()
maybe one kept driftin' west![]()
hey glenn. Good, been using the drag to kill weeds in the open areas before they take over, and the little tractor in the smaller spaces around the corrals. They're growing like...well, weeds
Fenlason wrote:
drag..
Fenlason wrote:I do want it noted that I exerted considerable effort to not edit that to drag queen..![]()
drag..
5 old semi tires lashed togther with cable. 2 across on the front row and then 3 in the second row. Makes it about 9 feet wide. Add some extra weight on top and it makes a great ground float. Levels things up pretty good after a couple of passes and tears the weed out by the roots. I use it in the large open spots. But its so heavy I have to use my pickup in 4WD to pull it in the soft ground, the little tractor can't even budge it
High Desert wrote:Fenlason wrote:I do want it noted that I exerted considerable effort to not edit that to drag queen..![]()
duly noted![]()
High Desert wrote:High Desert wrote:Fenlason wrote:I do want it noted that I exerted considerable effort to not edit that to drag queen..![]()
duly noted![]()
and besides, drag queens don't work worth a darn for leveling ground when pulled behind a pickup![]()
High Desert wrote:Fenlason wrote:Is it nap time yet..
man I wish
