starleen2 wrote:I'm the "nobody"
I thought you left us..
Fenlason wrote:well I am mostly loaded...
swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
well actually I don't..
starleen2 wrote:Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
only YOU could make it happen!
Fenlason wrote:starleen2 wrote:Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
starleen2 wrote:Fenlason wrote:starleen2 wrote:Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
Just get a little early start and take it trough the night
Fenlason wrote:starleen2 wrote:Fenlason wrote:starleen2 wrote:Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
I don't drink any more...
Fenlason wrote:well the new lumber hauling method was in improvement.. but it still needs work.
and man was it work getting out there. I was perhaps a 1/2 mile out... I had a bit of weight in the vehicle...and there are places it is quite lumpy.. and rocky...![]()
I have the bridge in place.. and most of the decking on. I did run out..![]()
It is not a straight shot to it. there is a bit of a turn at each end.. as you get on or off. So my first few pieces of decking on the other side I cut longer than the 24" so that meant I could not get 2 pieces out of each piece.
So I will have to go back out.. sometime. I might change some of the other pieces I have installed also.![]()
this one might be hairy.. It is 24" wide.. and on one side.. it is a 5' drop to the water. It also sloped.. uphill one way. and as I said you have to make a sharp turn to get onto it. sharp turn and fairly technical on either end.![]()
starleen2 wrote:Fenlason wrote:starleen2 wrote:Fenlason wrote:starleen2 wrote:Fenlason wrote:swissarmygirl wrote:Fenlason wrote:well I am mostly loaded...
ahhh I wish...
or any less???
starleen2 wrote:Fenlason wrote:well the new lumber hauling method was in improvement.. but it still needs work.
sounds a bit dicey to me!
