Receiver Hitch on back of Trailer frame
Postby mark Holbrook » Thu Apr 28, 2011 12:08 pm
Hi,
Thinnking about mounting a receiver on the back of my trailer to carry the bikes on a rack. Had it all designed and then thought about what it would do to tongue weight. I really don't want to play with the axle location so I think I might just not do it. Any thoughts or ideas?
mark Holbrook
Postby halfdome, Danny » Thu Apr 28, 2011 12:40 pm
Welcome to the forum Mark :shake hands: .
You could always put a counter weight of camping items in a tongue box if the bikes lighten the tongue too much. If you do put a hitch on the back make sure it is attached (preferably welded) to the rear and next cross member. You can get them up to 48" long :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Steve_Cox » Thu Apr 28, 2011 1:19 pm
Hi Mark,
Welcome to the forum. My 40 to 50 pounds of bikes and bike rack pictured only eliminated about 16 pounds of tongue weight at the trailer hitch. I made the receiver and bolted it to the frame with 5/16" carriage bolts. ( 5/16" grade 5 carriage bolts have a tensile strength of 120,000 pounds )
Steve_Cox
Images: 196
Postby egjacks » Thu Apr 28, 2011 1:55 pm
hey Steve,
do you find that the bikes affect your mpg at all? they kind of mess up the aerodynamics of the teardrop. I was considering putting a hitch on the back as well..
Eric
_________________
~If I fall flat on my face, at least I am moving forward.~
egjacks
Postby mark Holbrook » Thu Apr 28, 2011 2:48 pm
Thanks for the help. I have a northern trailer and a 48" long receiver. I guess I will go ahead and mount it up then see what it does to the tongue wait. Easier to attach it now then once all built.
mark Holbrook
Postby Steve_Cox » Thu Apr 28, 2011 4:03 pm
egjacks wrote:hey Steve,
Didn't notice any changes in MPG or increase of slipstream turbulence. 8)
Steve_Cox
Images: 196
Postby planovet » Thu Apr 28, 2011 4:05 pm
I did not add one on mine and now I wish I did. If you are building your frame, I'd go ahead and put one on. Better to have it and not need it than need/want it and not have it.
ImageMark (& Cindi)
planovet
The Cat Man
Postby 48Rob » Thu Apr 28, 2011 6:15 pm
The typical teardrop has the axle set further back than a standard trailer, affording the ability to add extra weight at the back end.
As has been mentioned, by rearranging things you can add weight to the front of the trailer to balance things if needed.
I don't know if having a bike makes mileage worse, but not having a bike would make camping worse...
Rob
<img src="http://im1.shutterfly.com/media/47b9d803b3127ccec739c8fec39300000040O02AbNGjdu5bMge3nww/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/">
48Rob
Postby dh » Thu Apr 28, 2011 9:03 pm
One thought on the reciever placement, don't let it stick out any farther than it absolutely has to, it is at the perfect height to knock shins while cooking in the gally.
dh
Postby madjack » Thu Apr 28, 2011 9:18 pm
I put one on mine to be able to mount one of those cargo carries...like for the backs of SUV's...I use it to carry firewood(and such)...I did place the axle a couple of inches back from where is would normally be...a few extra pounds on the hitch is not NEARLY the problem of too much weight on the axle...when using the cargo carrier, I keep in mind how I load heavier items, typically moving them forward to keep the balance near correct..................
madjack 8)
Postby Gary and Cheri » Thu Apr 28, 2011 9:19 pm
I put a 2" hitch on the back and on both sides. With a welded square "L" shaped adapter I can now put my work station for the stove and our eating table in one of three locations. Normally the rear hitch carries the spare tire when traveling. I needed alittle weight in the back as my tongue weight was close to 200 lbs.
Gary and Cheri
Postby AlStAubin » Sun May 15, 2011 3:09 pm
I was thinking about doing this so that I could attach a canoe carrier and put my canoe on top but keep it suspended off the trailer.
Keep on smiling, makes people wonder what you've been up to!!
AlStAubin
Postby bobhenry » Mon May 16, 2011 6:48 am
Once they are mounted you are only limited by your imagination. I have installed one on each and every one of my 4 builds. The Teardrop and barn both will be able to tow the chuckwagon in tandum.
and the bike rack will fit all of them.
I know I gotta get some pictures. :oops:
Postby dh » Tue May 17, 2011 12:34 am
Hey Bob, how legal is that? In most states (maybe all?) if towing tandem trailers the one in front has to be a 5th wheel or goose neck.
dh
Postby Cliffmeister2000 » Tue May 17, 2011 12:50 am
Indiana is the only state I am aware of that allows someone to tow 2 trailers, even when both are bumper pull trailers. ;)
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
