mikeschn wrote:starleen2 wrote:mikeschn wrote:starleen2 wrote:Mike - what's the width - I have traversed the bed before and got away with a 48" wide bed that will sleep two adults very comfortably with no crowding. It might give you a little more floor space. I'm 6'00" and the green lantern is 76" wide - I still have a few inched left at the end of the bed - so it could be a bit narrower depending on your height (while laying down)
Scott,
I was thinking about making the inside width about 72". That would make the outside width about 76". What's the inside height on your Green Lantern?
inside height is 5" 1 1/2"
That's perfect for a slouchie. Our Baja Benroy was almost the same.
or a standie - if your spouse is 5'00"
