Cliffmeister2000 wrote:I wonder how much foam is required to make a door-frame strong enough to support the roof structure...
Good question...
Maybe the door frame requires an internal rib made out of wood.
So many questions!!!
GPW wrote:Mike , The TB2 won't dry on just the foam to foam join ... tried it ...stayed wet inside for weeksgorilla Glue is the ticket ... or epoxy ... Since the foam isn't porous , there's no place for the Water based solvent to evaporate ...
GPW wrote:Anybody having serious doubts about the strength of this kind of construction can just add more material ... can't hurt to add more wood , or even fiberglass the whole thing ... That's the Beauty of the whole concept ... Build it like You want to ... when in doubt add more "strengthening"... it's all in what You need/like ...![]()
The Foamie trailer (well, Eagles ') we know is light ... so adding a little more material strength probably won't affect anything , hardly .. and you can leave out the brick floor ...![]()
mikeschn wrote:Cliffmeister2000 wrote:pretty neat, Mike! Is the tape holding the pieces together until glue dries, or is it just taped for show? If glued, what did you use to glue the edges together?
It's just taped together so I can show you guys...
My thoughts for gluing the edges together, is to find a flat floor. The floor of the carport sounds good for that. Then glue the edges with TB2. Put Duct tape on one side, flip it over, remove the duct tape and put the canvas on the other side. After it dries, flip it over again, and put canvas on that side.
But that's just my first thoughts... I've got to read this monster thread from beginning to end.
The most amazing thing about these two shapes, is that they are both 69" tall. The egg is 10' long and the standie is 11' long. But the standie looks so much bigger.
The standie...
The egg...
eaglesdare wrote:also i thought i read where you only used 2 pieces of foam for each side? from looking at what you have, it looks like you used 3 pieces?
