Let me tell you about my day...
Postby cracker39 » Tue May 03, 2011 10:11 am
Actually, my two days. If toilet stories gross you out, stop reading and leave now.
Yesterday, around 2 PM, while I was working on the cabinet doors for the Pop Top, my wife came out to tell me that when she flushed the toilet, it overflowed onto the floor and sewage came up in the bathtub. That could only mean that one, there was a clog, or two, the sewage pump in my lift station tank in the back yard had stopped pumping. It has to pump my sewage uphill about a foot to get into the street sewage lines.
I couldn’t understand how the pump had died less than a year after the city guys replaced the original that had burnt out. At the time, they told me the next one I’d have to pay for and I didn’t have the sales receipt for this one to make good on the warranty.
I opened the cap on the check pipe I had installed just below ground level and water came out. The tank was full and overflowing. I dug down to uncover the tank top, removed the top and pump and then went over to the city utilities and spoke to the boss to ask for advice. He came over and tested the wiring and declared the pump dead. Then he found what looked like some rag sticking in the intake that the blades couldn’t chop up, so it burned up the pump. (I found out later it was a medicated wipe that my wife had flushed down the toilet) He said if I got a replacement he’d be back over in a while to help me put it in.
I went to Home Depot to get a replacement. I bought a larger, cast iron pump and when I got home I called the guy at the utilities and described it to him and he asked if it said sump pump on the box. It did. Nope, I needed a sewage pump.
So, back to Home Depot to get a refund and buy a sewage pump. They had the same pump I had at home, but had a better quality pump of the same brand, more HP and GPM flow, so I bought the only one they had.
I brought it home and took it out of the box to test it to make sure it ran. As it handled larger waste solids, I look at the bottom opening…it looked the same as the one I had in the tank. I checked the model number on the pump. It was the cheaper model, not the one that was supposed to be in the box. Someone had, accidentally or purposefully, swapped punps in two boxes. Home Depot got ripped off and so did I.
:x
OK, back to Home Depot for the third trip to get a pump. No more of the “betterâ€
Dale
cracker39
Images: 233
Postby starleen2 » Tue May 03, 2011 10:24 am
Some days it hits the fan - other days it hits YOU. the other day wasn't a fan day :D
starleen2
5th Teardrop Club
Postby Shadow Catcher » Tue May 03, 2011 10:26 am
I so love working on plumbing particularly the, shall we say out put side. I have given up on Lowe's et.al. for sump pumps, check valves etc. way too many trips and problems. I now go to the local been there for a gazillion years plumbing supply. Prices not much worse and the refuse to sell junk.
Postby bledsoe3 » Tue May 03, 2011 11:34 am
What a crappy day you had.
bledsoe3
Images: 112
Postby asianflava » Tue May 03, 2011 12:34 pm
Holy crap! .... err crappy hole!
Had septic at the other house, it was the newfangled job with air pumps and sprinklers that watered you lawn instead of using a leach field. What I didn't pay in sewage bills went to the county for a quarterly inspection. No septic here, I don't miss it.
asianflava
Re: Let me tell you about my day...
Postby robfisher » Tue May 03, 2011 1:36 pm
cracker39 wrote:As I had already stopped at HD earlier in the day for some hardware and lumber, that made four trips there and back in one day…my new personal best.
Dale, Let me get this right. You built your own trailer and your personal best is only 4 trips to HD. Oh my! How I admire such organization!
I was on the 6-a-day plan for the last two weeks of my build.
robfisher
Postby SteveF » Tue May 03, 2011 1:56 pm
We've been having intermittent sewage back up issues in my building* for a few months now--a big construction project down the line (as it were) has blocked off a bunch of pipes. Just the usual-sewage coming back out the toilet, out the bathroom floor drain, that sort of stuff.
The other day it was coming out of the drains in several drinking fountains! Yuck!! And while we were going around putting "out of order," signs on them, we had to stop one kid that was trying to drink out of one, her nose a couple of inches from the burbling black mess...
*(I work at a big 10 university library)
SteveF
Postby eamarquardt » Tue May 03, 2011 2:48 pm
At least you could walk away for a breather! One of the many drugs used in an attempt to treat my defective cranial nerves (read PAIN) is an antidepressant called Depakote. One of the side effects is unpredictable, sudden, EXPLOSIVE movements of the 2nd kind.
I had a couple "accidents". They were not pretty or fun but they were fragrant and they happened at most inconvienent times. I decided Depakote (along with everything but opiates) wasn't an effective drug for me.
Consider yourself fortunate to have an "external" problem.
Cheers,
Gus
eamarquardt
Images: 150
Postby stevem50 » Tue May 03, 2011 7:16 pm
i got a story for you along these lines that might make you laugh at my expense...
so a while back i had a clog in the bathtub drain, no biggie, snaked it and had some liquid plumber in the cabinet. poured half the bottle in, so far so good, it says let it sit about 15 min, so i figure it cant hurt to dump the rest of the bottle in the sink drain and for good measure some in the toilet... hmm
i have a dog so down goes the lid on the toilet...hmmm
i also have NO short term memory... HMMMM
a few minutes go by and nature comes a calling, i flip up the lid (forgot why it was down) and i let er' rip, to my surprise i got a splash to the rear, and IMMEDIATELY remembered why the lid was down.
i would trade the experience of some sewage for the chemical burn to the evil eye i got.
stevem50
Images: 15
Postby mikeschn » Tue May 03, 2011 7:21 pm
Hope you have a better day tomorrow.
P.S. I told you, you should have called it a squishy!!!
Postby dmckruit » Wed May 04, 2011 6:41 am
Dale,
Make sure you check the pump manual. Some pumps require you to drill a hole in the intake line. Otherwise the pump will vapor lock and eventually burn out. I've been through this before.
Dave
dmckruit
Images: 212
Postby Mightydog » Wed May 04, 2011 11:51 am
"If it wasn't for bad luck, I wouldn't have no luck at all."
--Albert King
Mightydog
Postby southpennrailroad » Wed May 04, 2011 6:12 pm
I do hope the wife understands that this was her baby!!!!!! Did you get a special I LOVE YOU HONEY/OOOOPs reward???????
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Postby JuneBug » Wed May 04, 2011 10:55 pm
cracker39 wrote: If toilet stories gross you out, stop reading and leave now.
Gosh, I bet you were totally pooped after two days like that.
(Sorry -- Could. Not. Resist)
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
