by GPW » Wed May 04, 2011 6:11 am
I think Gary (Rayvillan) is on to something ... the forces involved in bending are tension and compression ... Foam is very strong in compression , but in tension the top surface wants to pull the surface apart , causing the break .... Foam breaks in tension , and as we've found , heat relaxes the surface under tension allowing it to bend ( it becomes more flexible )
If the surface is covered like Gary did , the tension forces are now on the covering material and not the surface of the foam ...allowing it to bend safely ... Now I'm sure that 1" foam covered as Gary did would bend easily around a large radius , especially on a warm day ... Possibly even the 2" foam ... once covered on the top ... It would take some straps and muscle to slowly bend the 2" , but I think it's doable .... attach one end , then slowly bend in the contour .... and a little heat from a Carefully applied heat gun should help ... Once bent with heat the foam stays in that shape with 0 spring back ... In the industrial world , we've seen strip heaters , long flat devices much like an electric blanket ... but much hotter ... so anyone having access to some type of heater should be easily able to bend foam ..
Just another thought .... If we're covering the inside first , like I'm doing now, that may be OK on a flat surfaced Weekender type , but if we bend the foam for a rounded surface , the inside covering may wrinkle with the bends ... so with rounded surfaces , you may want to cover the inside last ..
