swampjeep wrote:question on these kerfs, once you have them cut, and you know the foam will bend to the desired rad. would you dab a line of glue in the kerf so it strengthens the faom and locks in this rad? or is this not needed? or possibly even mess it up somehow?
GPW wrote:DON'T PANIC !!! The sanded surface adheres much better (the tooth) , and Now I'm trying the full strength T2 instead of the 50/50... and remember the household iron is your friend ...I went back on some suspect areas , and ironed them @ 275F and now they are darn near impossible to remove... so any lifting can be quickly taken care of with the iron ...
I believe the extra heat actually slightly melts the fabric/glue into the foam ...
For joining foam to foam with the fabric in between, I plan to perforate the cloth with a pounce wheel which will create little glue "nails" through the fabric and foam (gorilla glue) ... Should be plenty strong ...
' Cars , the 1/2" will bend easily on large radius bends , like a TD , better with a little heat ...![]()
HAL... That would probably work great too... just we haven't tried that .... as yet ... Many glues yet to be tried ... Who'll be first ?
Ratkity wrote:... I think full strength T2 is the key. That stuff is going nowhere.
Hugs,
Ratkity
Ratkity wrote:GPW wrote:DON'T PANIC !!! The sanded surface adheres much better (the tooth) , and Now I'm trying the full strength T2 instead of the 50/50... and remember the household iron is your friend ...I went back on some suspect areas , and ironed them @ 275F and now they are darn near impossible to remove... so any lifting can be quickly taken care of with the iron ...
Eagle and I had no problem with the canvas even thinking about coming off with the full strength T2 glue and also with the copious amounts that were used. The glue permeated the canvas. We also wrapped it under the wood floor and had it stretched smooth and attached it with a staple gun. I think full strength T2 is the key. That stuff is going nowhere.
Hugs,
Ratkity
