bdosborn wrote:Whoa, whoa, whoa, slow down. No need for any type of switching arrangement. Just wire the output of the solar controller directly to the battery and not through the WFCO. The solar controller output is controlled by the battery voltage. If the battery charger is on, the solar controller will read the battery as charged due to the higher voltage from the charger and will shut down the solar output. Solar controllers are designed to work with battery chargers so there's no problem with running them both at the same time.
8ball_99 wrote:
But the issue is wouldn't that work both ways.. The WFCO is also a multi stage charger and will shut off if the battery is charged.. If both chargers are connected to the battery during the day plugged in wouldn't both chargers conflict?
