eaglesdare wrote:GORILLA GLUE WORKS! GET A SPRAY BOTTLE AND FILL WITH WATER. SPRAY ONE SIDE THAT YOU ARE GLUEING TOGETHER AND THE OTHER SIDE USE THE GORILLA GLUE. IT WILL EXPAND, FOAM OUT. BE PREPARED WITH LOTS OF PAPER TOWELS. OR SAND AND SCRAPE LATER.
WE ONLY HAVE 2 WOOD BLOCKS FOR THE HINGES ON OUR TEAR. THAT 2" FOAM IS VERY STURDY. YOU CAN MAKE A NICE DOOR WITHOUT MUCH WOOD, I DON'T BELIEVE YOU NEED A FRAME AT ALL.
I WISHED THEIR WAS SOME WAY TO "SHOW" HOW STRONG THIS THING IS.
I WOULD ONLY USE THE T2 WITH THE CANVAS ON FOAM.
GOOD WORK WITH YOURS.
Anita Rae wrote:Wat is the purpose of the water here? I'm sure it was explained somewhere in this post but I can't find it and Hubby is asking.
GPW wrote:Probably not , and you might be able to arrange it on an 8' floor , only two partial sheets of ply ??? Best made the 6' + the width of both walls ... for a true 6' inside ...![]()
You want me to make a drawing that size that you can print out and draw on ???
GPW wrote:The quality is remembered long after the price is forgotten, so build your teardrop with the best FOAM materials...![]()
