Well they are a screw so that is probably good right? That way you can adjust them completely as required as compared with auto jack stands that usually are set in increments right?GuitarPhotog wrote:I use these stabilizing jacks to level my TD. It doesn't make a lot of difference for sleeping, but I hate cooking on a stove that is not level.
They ain't great, but they're inexpensive
http://www.amazon.com/gp/product/B000760FX4
<Chas>
I think your idea of checking out local thrift stores is a good one. I am not a giant hurry so who knows. I am building a small pop up top so maybe I need to stabilize all four corners. Though my build goes kind of pointy in front.doug hodder wrote:Thrifty is where you find what will work at the cheapest price. I use the Atwood jacks not cheap, but it's what I use, they fold up really nicely with no hang down. Less expensive options can be had at a wrecking yard or pick and pull, for auto screw scissor jacks, thrift stores have also turned up regular trailer stabilizers for next to nothing. Automotive scissors fold down really compact, and I'd think they could be had for very little....call the local yard.
I only stabilize/level the rear on the tear, just open the doors and jack till they flop open evenly...on the standy...I do all 4 corners. Doug
Personally I am on a rather tight budget, so for me this is a little cost prohibitive. Old car scissor jacks might be an option.Artificer wrote:Depending on what you consider thrifty, take a look at these scissor jacks:
http://www.campingworld.com/shopping/it ... ystem/6540
$70 for a pair, I believe. 4"-24" adjustment range.
For even cheaper ones, but without the large range, you can go to the junk yard and get a pair from old cars. It depends on your trailer if they have enough range of motion.
Michael
I like your style. You have a great game plan there. I will give it a try.KIDZAGN wrote:Hey Stand Up, auto salvage sissor jacks are the way to go. Find a Mom & Pop yard, and go "shopping". Find a design you like for your use, size of base plate, top plate , does it use a hex head and wrench or slot & crank rod. The choices are many, when you find one you like, find 3 more make & model cars containing the jack you like, take them all to the office and offer Pop $20.00 for them all.... He will say no way! $40.00! then you"ll say then he will say ........ you get the idea.. but you will have 4 jacks for about 1/2 the price of 1 new one, and the truth is the ones at the salvage yard may have never been used either.
I'm not cheep, just creative
Mike
I suppose a variation on that might be to make some sort of box and have a few board sections and some wood shims to finish it off.bobhenry wrote:I carry construction lumber for fire wood so side to side leveling is never a problem. Stack a few short boards and back up on them while still hooked up. Might take a couple of trys with a couple combinations of wood thickness but you are soon level at no cost.
