GPW wrote:Funny , when I used to sleep in a tent , I never even thought about tree limbs ...For those so worried , maybe a bit of fiberglass just on the roof (the heavy stuff)... Why you could even treat it like canvas and secure it with T2... The epoxy (or the polyester , not used on foam ) resin is the heavy/messy part ...the FG cloth is STRONG ...
Spars ... That's why I thought of using the foam arch , which spreads the loads out effectively where needed .. a spar , covered and glued in so it's perpendicular to the roof , should be plenty strong .... if you don't plan on standing on it ...
swampjeep wrote:
the arches across the front provide small corner shelves, but are actually support for the side to front
GPW is this what you had in mind?
Ratkity wrote:I love the CAD drawings!
I'm glad you showed the arches. It sorta looks like a place to bump the head or have to continually duck around them. I think I still like the straight line of the spars inside.
I wouldn't use foam covered in canvas as flooring. Underneath there would be horrid rock and road debris dings - and inside, it would get dented or eventually totally compress in walking areas (I'm thinking of the standy) because the canvas does have a wee bit of flex to it.
Putting a raised bed inside with just framing would add lots of support to the side and sure would be easier to get out of bed in the morning. Underneath can be used for storage of bedding or the porta potty when not in use so it doesn't run around the foamie while driving (unless permanently installed elsewhere). I can envision bunk beds for the kids on one side if the foamie standy was 6 ft wide. So many possibilities!!
Hugs,
Ratkity
