Foam TD (build journal)
Postby eaglesdare » Mon May 09, 2011 8:37 pm
holy cow! yours looks fantastic!!!!!!!!!!
Louella
May the foam be with you.
eaglesdare
Postby Miriam C. » Mon May 09, 2011 10:22 pm
:applause: :thumbsup: :thumbsup: VEry nice! I hope the glue holds up for you. I dislike Gorilla glue... :(
Postby pat g » Tue May 10, 2011 12:32 am
Thanks Eagle. Ashtabula is East and North of me. I am 30 miles South of Cleveland via I-71. I paddled the Ashtabula river a couple of weeks ago though. BTW What kind of door latch did you use for your foamie? I think that I am going to do like you did and finish the exterior and make it campable then decide how I want to finish the interior.
Miriam, Actually I did not use any Gorilla Glue in this build. I used only Titebond II and 2 types of construction adhesive both made by Locktite. GG is a good product for a lot of tasks, just a bit messy. I have used it for a lot of woodworking projects. I just thought that I'd try something new so I used the adhesive specially made for foam. Like anything else, it comes down to what materials you like to work with.
SYOTR
Pat G
pat g
Images: 122
Postby eaglesdare » Tue May 10, 2011 7:05 am
i used simple lowes latches.
my storage latch is the same as the first one. the second i had to use one with a lock. they ran out of the first one.
now call me paranoid, but i make sure that when i go to sleep, the lock is on and closed and the other latch is locked and in the closed position. this will prevent any one from pulling a prank on you and locking you inside your tear. :lol:
make it campable and get out there. my insides are so not done, but there is a bed and its campable.
Louella
eaglesdare
Postby pat g » Tue May 10, 2011 8:31 am
Thanks for the reply and info Eagle.
Pat
pat g
Images: 122
Postby HandyAtLeast » Tue May 10, 2011 10:55 am
This is looking really good!
I make stuff, and it's all designed on Post-Its... the small ones.
HandyAtLeast
Images: 22
Postby b.bodemer » Tue May 10, 2011 12:25 pm
Pat,
Great looking foamie you are building!!!!!!!!!!!!!!!!
Barb
b.bodemer
Images: 328
Postby GPW » Thu May 12, 2011 8:16 am
Pat ,you had a chance to do any more ... ??? Sure is looking Great !!! :applause: Bet the inside will be Nice too , the wood and all ... 8)
Postby pat g » Thu May 12, 2011 10:22 am
Thanks for the comments everyone. Barb, was wondering how long it would take you to find this. LOL
Last couple of days, I completed skinning the TD. Trimmed all edges best I could, ironed the whole thing. Skin came out tight and smooth. Hint, if you are using canvas drop cloths from HD, and need to cut them, brush a bit of watered down TBII along the cut line and let it dry before cutting. This will prevent fraying of the fabric. All I have to do to finish the exterior is paint, install the window, and make a door. Then I can mount on the trailer and finish the interior. I'm heading out now but here are some pics of progress.Image
BTW GPW There's not that much wood in there!
pat g
Images: 122
Postby eaglesdare » Thu May 12, 2011 12:00 pm
great tip to prevent the fraying! gpw also recommends pinking shears.
but your tear is looking really really good! so you are not going to cover in the diluted t2?
Louella
eaglesdare
Postby GPW » Thu May 12, 2011 3:48 pm
Thanks Pat!!! Covered looks Fine !!! :thumbsup: 8) :D
Surprised no body used pinking shears ... Oughta' go great with Pink foam ... :roll: :lol:
Postby eaglesdare » Thu May 12, 2011 5:48 pm
GPW wrote:Thanks Pat!!! Covered looks Fine !!! :thumbsup: 8) :D
if i could have found the one pair around here somewhere i would have used them. :) this canvas stuff frays horribly.
Louella
eaglesdare
Postby pat g » Fri May 13, 2011 7:06 am
after reading all the discussion about paints and sealing, etc. I just went straight to a good quality primer. The thing soaked up almost a full gallon of primer in one coat! Pinking shears? I forgot all about that. That actually would give character to the seams. Yesterday I got on the first coat of color. My wife picked out a kind of grey beige to match my S-10. I think it looks good. Gonna be busy the next few days so I'll be updating with new pics and progress early next week.
Have a good weekend.
Pat G
pat g
Images: 122
Postby eaglesdare » Fri May 13, 2011 7:14 am
i used the diluted t2/3 on top of the canvas. then when i put the primer on it only took less than 1/2 a gallon?
so i can see where if you don't use the dt2 then your canvas soaks up more primer.
hmm which one is cheaper to use. i think they both will work just fine.
Louella
eaglesdare
Postby pat g » Mon May 16, 2011 8:20 pm
Hey All,
Did not get to do too much today but I did manage to get the window installed and add wood to the door for hinges and a latch. Gotta let the glue dry before covering the door.
SYOTR
Pat
pat g
Images: 122
