I just knew this Had to come up sooner or later ...
Last night I used common spray foam to fill in the gaps in my roof , and used vinyl spackle on the dents ... Both worked Very well .... the foam expanded and sealed the roof , this morning I cut off the excess with the recommended serrated knife and will just have a little sanding to make things flush and ready to cover...
The spackle is still a bit soft (rainy/Humid here), on the thicker areas , but the thin areas , just sanded smooth very quickly ...
For repairing damaged areas , spray foam and a patch are the logical alternative... Or you can symmetrically cut away the damaged area entirely , and just replace that with more Styrofoam , then patch ...
So for a Foamie first Aid kit , you might want to carry a can of spray foam , some extra canvas/fabric ,scissors, serrated knife (small table size) , a small bottle of T2 and GG , a small cheap brush , and a little jar of matching paint ... All would fit in less than a shoebox...
This is especially where those pinking shears come in , making a "soft " looking seam edge that blends in better than a hard edge straight cut .... less fraying too ...
, less likely to peal off ... A trick used to patch fabric covered airplanes for Many many years now ...
