sealing birch
sealing birch
Postby Burro » Thu May 12, 2011 10:21 pm
What does everyone do to protect the interior walls? I really like the nice clean look of the birch walls but I think I may need to seal them? I am worried if I leave them without a sealant then cleaning them will be difficult or they may get stained. I have 2 dogs I am sure will brush up against the walls at some point.
What did everyone do? I used polyurethane on the exterior should I use this on the inside. Will it darken the wood or make is shiny? It seemed to do this on the exterior plywood.
Burro
Postby KenC » Fri May 13, 2011 2:51 pm
Hi there,
I sealed my inner walls with Polyacrylic Satin finish by General Finishes, 4 coats, sand with 240 between coats, it is truly a clear finish which claims will not yellow with age.
Rockler General Finish link and reviews
http://www.rockler.com/product.cfm?page ... l%20finish
KenC
Images: 41
Postby MarkD » Fri May 13, 2011 2:55 pm
Hi Burro,
You will want to seal the inside - there will be condensation. I used a varnish which yellowed the wood in a good way, but if you want it to be clean looking an epoxy should work good. A good paint store can set you up. Whatever you choose, try it on a piece of scrap first just to make sure.
Have fun, Mark
MarkD
Postby Woodbutcher » Fri May 13, 2011 3:29 pm
Minwax Helmsman. Tough as nails. Used it in the galley also. Water proof and UV protection to boot!
Woodbutcher
Postby emiller » Fri May 13, 2011 4:33 pm
I buy most of my wood from here http://www.woodworkerssource.com/ and am doing birch in my standie. They sell and recommended this to me they told me to seal it with this http://www.deftfinishes.com/trade/produ ... ing-sealer and then finish it with this http://www.deftfinishes.com/trade/produ ... ng-lacquer so far I love this stuff.
emiller
Images: 157
Postby mikeschn » Fri May 13, 2011 7:36 pm
Woodbutcher wrote:Minwax Helmsman. Tough as nails. Used it in the galley also. Water proof and UV protection to boot!
I used the same. Good stuff!
Postby Nobody » Sat May 14, 2011 10:29 am
Yep... & yep - the Minwax Helmsman Spar Urethane brings out the natural wood grain without changing the color(hue?). I used it on birch plywood in my galley, & on oak plywood in the cabin, & after nearly 5yrs it's required only minor 'touch-up' to keep it looking good & performing well -
Harvey -
Nobody
Images: 342
