Cliff
GPW wrote:Interested ...Oh Heck Yeah !!!!! It's coming along really quick... You going to pre cover the outside ... probably easy to do at this stage (flat)... JMHO, I'd lay it out flat , roll on the glue and just lay the canvas into that, trim and let dry... you may have to stretch it a bit so somebody else would be handy... and for the best job , you might ask, beg ,bribe Chell to iron the fabric for you with a steam iron ... if the material was folded then those wrinkles will come out in the finish (subtle )...gotta' get those out if you want a perfect finish .... also good to thoroughly vacuum the foam surface , make sure the canvas stays Clean .... tiny bits of anything turns into a bump ...but you can push in on it and they usually disappear ... best clean from the get go... just trying to be helpful...
swampjeep wrote:GPW wrote:Interested ...Oh Heck Yeah !!!!! It's coming along really quick... You going to pre cover the outside ... probably easy to do at this stage (flat)... JMHO, I'd lay it out flat , roll on the glue and just lay the canvas into that, trim and let dry... you may have to stretch it a bit so somebody else would be handy... and for the best job , you might ask, beg ,bribe Chell to iron the fabric for you with a steam iron ... if the material was folded then those wrinkles will come out in the finish (subtle )...gotta' get those out if you want a perfect finish .... also good to thoroughly vacuum the foam surface , make sure the canvas stays Clean .... tiny bits of anything turns into a bump ...but you can push in on it and they usually disappear ... best clean from the get go... just trying to be helpful...
I hear if you dampen the canvas, and throw it in the drier for a few minutes, it will take the wrinckles out... but that's just what I've heard.
GPW wrote:Mike ,That looks great !!! Nice and snug !!! Anxious to see your thoughts on the door frame ... and door framing ...
Thanks Ratkity. GPW helped!Ratkity wrote:Very innovative on the window design. Love it!
eaglesdare wrote:wow, that is fantastic. its a shame the rain put a damper on things. you are going to have a nice looking trailer when its done.
eaglesdare wrote:hmm, is there really a need to rough that stuff up? i know the kind gpw had was a glossy skin, but the stuff you are i am using is not.
i did not rough my surface up. so do you think this is necessary? is there an added benefit to it?
