Continue peeling T3 off my fingers
Dilute T3 (1:1) and cover top and edges
Figure out how to put straps on - was thinking of getting a small strip of cloth and T3ing the ends and sliding the strap through that. I might delay doing this until the panel is mounted so I can see the best placement of the straps.
Already made the adapter pigtail for the new connectors on the solar panel to the solar controller. Will test tomorrow between rain storms.
Already took out the non-functioning radio antenna from the TD and sealed it up (where the panel is going).
Bought stainless steel screws for attaching brackets to the TD (expensive!)
Drill holes for brackets in panel.
Mount and adhere brackets to TD.
Mount solar panel
Approximate costs:
Solar panel - $220
Brackets (4) $5 - for mounting panel to TD
Screws, stainless $15 - for mounting panel to TD
1" foam $9.75
16 oz Titebond 3 (x2) $15
2 yds pepper cloth $15
Straps and buckles $15
Duck cloth - scrap
Upholstery cloth - scrap
Gorilla glue - small bottle that was hanging around from another project
Hugs,
Ratkity
edited to separate panel and cover costs!
