stomperxj wrote:Let's talk foam coverings. I posed this question in Mike's Foamie Standie thread but thought it would be a good subject to cover by itself...
I see that a few of you that are working on your foamies are using canvas to cover the outside with some kind of glue like Titebond for adhesion. Here are a couple questions for discussion:
1. What are the advantages/disadvantages of using canvas over fiberglass cloth?
2. How waterproof is canvas?
3. Is using canvas over glass strictly cost related?
4. Is there another covering material besides glass and canvas that would work?
Discuss-
Jess
eaglesdare wrote:another question about this. can you use that glass cloth with glue? leave the smoothness out of the equation. just wondering if you could use glue, and if so would the glass cloth be strong?
i know nothing about that stuff, so i am interested in the answer.
i used the canvas/glue method, because when i first read about it, it was exactly like gpw stated above. it was cheap enough, i could buy it locally, i could do it without any special tools. and it works. it is lightweight (enough). thanks for the compliment on mine gpw, but mine really isn't that great looking. it really only matches the car. but a person with a bit of time, and does it right can make a really nice looking one. hopefully my second one will look much better. gpw's with the round edge looks great, and i have the feeling that mike's is going to be another great build.
stomperxj wrote:Great answers guys... Keep em coming-
How about a strength comparison between the two?
How would a canvas covered shell take a limb strike from a tree on a logging road vs a glass covered one?
swampjeep wrote:when you say glass in this compare, are you stating glass w/resin, or just titebond?
stomperxj wrote:swampjeep wrote:when you say glass in this compare, are you stating glass w/resin, or just titebond?
I'm talking with resin, not Titebond.
Just was curious if anyone had done a durability test with the canvas. Like make up a test square, let it cure and then hit it with a hammer to see what kind of impact it could take or if there was any kind of failure...
GPW wrote:Er, actually the foam does have some strength ,a good bit , we've used it for many years to great acclaim ... and while we're not on a quest for the ultimate TD here, building to the parameters stated produces a camp able structure that is affordable and can be built by most anyone... with little to Rot...
Better than a tent , not as strong as a Tank...
Someone please remind me to bring a hammer to a TD gathering , so I can test the strength of others trailer materials... May not be popular , but we'd gain some empirical evidence...
And although there's much speculation by some as to "what if", the same may be said for most any of the other TD construction methods ...
