tinksdad wrote:GPW wrote:
Just wanted to get something on the 100th page of this topic!!
wahoo, we did it. who would have ever thought that. look at what you started gpw aka the bear!!!!!!!!!!
eaglesdare wrote:i've got bad weather here today. rain, and rain. so i can't even do the measuring stuff. so i might (perish the thought) have to clean the house?![]()
wished i knew how to do those sketches with cad, would love to play with some inside design ideas.
there was a guy on tv a long time ago, that used to say "if you can't build out build up.
and in my case i can't do much "out building" but i have room for upwards building. so my mind has been going all over the place.
DJT wrote:Eagle, I was playing with the idea of having a rear door under my hatch, just to limit openings for water/dust penetration... Still on the drawing board for the second one maybe![]()
I should have the initial plans done this week, just found a local axle for cheap, just hope that I won't have to change my frame design!
Dave
GPW wrote:Got my door to fit ... marked the lines for the outer wood framing surrounding the foam ... Now to cut and fit/glue that accurately ...![]()
DJ, I'll be running the interior reinforcing strips once we're done on the outside ... 8" wide with a centerline ... 4" overlap in each direction ...
