Foam TD (build journal)
Postby pat g » Wed May 18, 2011 9:06 pm
Thanks for the compliments everyone.
Eagle,
I have some foam weather strip laying around and plan to use that as a seal. I may also make a T moulding for the outside with a piece of aluminum I bar that I have laying around. That would provide a double seal to the door. For a latch I plan to use a garage door handle. Just have to figure out how to make the latch portion inside.
SYOTR
Pat
pat g
Images: 122
Postby eaglesdare » Thu May 19, 2011 7:04 am
Louella
May the foam be with you.
eaglesdare
Postby GPW » Thu May 19, 2011 7:15 am
Sealing the door ... That's always the question ... :thinking: Gotta' keep the water out ...
Postby pat g » Fri May 20, 2011 10:17 pm
Latest news. I wedded the cabin to the trailer today. Hung the door and trimmed it out.
SYOTR
Pat
pat g
Images: 122
Postby pat g » Fri May 20, 2011 10:22 pm
The extra space around the cabin will be decked in wood plank to be used as a shelf while camping. I also plan to add some planking on the tongue to carry a cooler or a box for wet paddling gear. I also have an idea for a fold up canopy. The wood planking would be a great place to attach the poles for the canopy. An added bonus of having the cabin inboard of the trailer frame is that the foam body is protected. :thumbsup:
Pat G
pat g
Images: 122
Postby GPW » Sat May 21, 2011 5:41 am
Pat, that looks really Great !!! I see your trailer is wide like mine , and we'll both have that situation ... :thumbsup: Any ideas on the weight yet ... it must be pretty light ...
Postby pat g » Sat May 21, 2011 12:39 pm
I am going to guess at the weight being a little heavier than eagles. Hers came in at #500. I'll guess at mine being #600 due to the heavier trailer and the lauan interior plus a little wood here and there. I think that my floor structure is a bit lighter than hers. I'd like to find a place to get the trailer weighed for free. Costs $15 at the stone place nearby. I put the cabin on the trailer by myself lifting one end and rolling the trailer under as I went. Other end was on my floor jack. The cabin cannot be that heavy because, at times, I was holding up the end with one hand and rolling the trailer with the other.
I'll have pics later of the wood I used to trim out the trailer. Only cost me $12 for treated fence boards. Should last a while and be light weight. After they dry a bit, I'll paint the boards. I am going out now to work on the trailer lights and the door latch and seals.
Pat
pat g
Images: 122
Postby GPW » Sat May 21, 2011 12:42 pm
Sure looks SUPER !!! 8) 8) 8)
Postby mikeschn » Sat May 21, 2011 1:22 pm
Pat,
That looks really good.
Did you use any wood reinforcement above the door?
Postby pat g » Sat May 21, 2011 11:28 pm
Thanks Mike,
There is an oak frame around the door opening then canvassed over. The oak frame was glued in.
Pat
pat g
Images: 122
Postby pat g » Sat May 21, 2011 11:39 pm
Hey All,
I worked on decking out the extra width of the trailer frame and tongue. I figure the tongue will be a good place to put my cooler. The tongue platform can also serve as a place to cook.
I added the door handle. A garage door handle worked pretty well. I have to finish re-installing the lights. I did not like their original position so I made some new brackets tonight and will re-position them tomorrow.
Here are a few pics.
New tires next week then hope to get it out for a maiden voyage. I plan to camp in it this Summer, with the interior unfinished, then decide just what I want inside so progress will slow down for a while.
Pat G
pat g
Images: 122
Postby GPW » Sun May 22, 2011 5:48 am
Love those running boards ... :thumbsup: 8)
Postby pat g » Sun May 22, 2011 7:20 pm
Latest pics with lights wired. Ready for tires and grease the bearings. Should be road ready then.
Pat G
pat g
Images: 122
Postby eaglesdare » Sun May 22, 2011 7:38 pm
pat that really looks great. you are doing a fantastic job. i am not sure what your weather gets like, but if it gets warm to hot, please plan now on a/c!
i just could not believe how hot it got last night in there. that will be what i will be working on next.
can't wait to hear about your first trip though, i hope it works out for you like it has for me so far. :)
Louella
eaglesdare
Postby Wobbly Wheels » Sun May 22, 2011 9:44 pm
Build's looking good, Pat. A thought occurred to me while reading your thread:
Given that you want to use the tongue for a cooler and you have the space along the sides, have you thought about combining your 'running boards' and external fenders with a spot for the spare ?
It would take a much more artistic eye than mine to make it look good, but there might be some cool styling cues there.
I'm thinking loosely along the lines of these:
Wobbly Wheels
