StandUpGuy's TTT (Not-a-RV)
Postby StandUpGuy » Sat May 14, 2011 3:46 pm
Here I have the rear of the trailer roughly framed and attached. I have one of the side frames C clamped on to check fit and placement of blocking.
By justoneman at 2011-05-14
StandUpGuy
Images: 52
Postby StandUpGuy » Sat May 14, 2011 3:49 pm
Window is put in place for the moment to check fit. I obtained the windows from a used truck cap for the total price of $35.
StandUpGuy
Images: 52
Postby Cliffmeister2000 » Sat May 14, 2011 4:04 pm
StandUpGuy wrote:Image
Very nice! :applause:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby StandUpGuy » Sat May 14, 2011 4:58 pm
Nice of you to say Cliff. Ofcourse the wall is not all framed out yet. I am working now on placing diaganals in the wall. When I am done with that I am going to copy the parts cut and make the other wall frame and then begin skinning them. It is getting kind of exciting now because this is the point where it starts looking like an actual interior space.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 15, 2011 4:08 pm
I have skinned the inside of one side wall and the back wall. I have also cut the material to do the frame of the other sidewall. My skinned wall went up to locate some blocking for the dinette seating.
By justoneman at 2011-05-15
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 15, 2011 4:09 pm
rear view:
StandUpGuy
Images: 52
Interior view:
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 15, 2011 8:51 pm
If you noticed in the photos I have a pretty wide rear entry door. Part of my plan is to make the "fridge cabinet" bolted to cleats on the floor and thus removable. I would be doing this because I want to have the option of rolling my motorcycle into the trailer. The door is wide enough to accept the bike and if the fridge cabinet is removed there would be enough roome to roll it in. I would have a removable wheel chock between the dinette seats.
By justoneman at 2011-05-10
StandUpGuy
Images: 52
Postby StandUpGuy » Wed May 18, 2011 3:54 pm
Plan view of trailer in "Cargo Mode". Fridge cabinet and small dinette seat removed to allow motorcycle to be loaded inside.
By justoneman at 2011-05-18
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 22, 2011 2:47 pm
The second sidwall is framed and both side walls are insulated.
By justoneman at 2011-05-22
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 22, 2011 2:50 pm
The main stationary ceiling panel has been constructed and installed.
StandUpGuy
Images: 52
Postby StandUpGuy » Sun May 22, 2011 2:53 pm
Its starting to look like an interior space. Pardon the debris. I am running out of space in the garage. Also it is 90 freaking 3 degrees here today. I am too dehydrated and tired to make a clean photo.:)
StandUpGuy
Images: 52
Postby StandUpGuy » Wed May 25, 2011 7:23 pm
built the panel that forms the nose of my mini land vessel. Designed to cut through the windstream. This panel was crucial to get right as the others will be easier to measure and make if this "keystone" is in place and correct.
By justoneman at 2011-05-25
StandUpGuy
Images: 52
Postby StandUpGuy » Wed May 25, 2011 7:24 pm
StandUpGuy
Images: 52
Postby StandUpGuy » Sat May 28, 2011 1:33 pm
Hope to finish the shell this weekend. Here is what I have so far. This is only c clamped in place but it strengthened up the trailer a lot. Sorry for the cut off top photos.
By justoneman at 2011-05-28
StandUpGuy
Images: 52
