I too am a bit boggled by how fast this thread grows...you folks sure are a gabby lot
Having a tendency toward verbosity myself, I have a couple questions.
Pat mentioned this a bit above and I think Eagle's got some first hand knowledge...
Does body heat make a difference inside these things ?
My trailer will be a bit bigger than most here, but I'll also have two people and two dogs as furnaces.
GPW - it seems to me that you wouldn't need the drip tray with a slide-out AC. If the only time it would drip is when it's running, it would be slid out. Would a couple drain holes in the 'shelf' not solve the problem ?
Lastly, what do you folks think about using one of these portable AC units instead of a fixed-mount wall hung unit ?
It *should* be easier to design a spot for it, right ?
Also, since I'm pretty well committed to a 2kW genset to give 'Mrs Wheels' some creature comforts, so powering it or the IR heater wouldn't be an issue.
