Water Inlet
Water Inlet
Postby StandUpGuy » Fri May 27, 2011 8:13 pm
water inlet. is there something I can use for my water intake inlet, that I might get from a local store or do I need to go RV with it? I really do not wish to make an access hatch if I do not have to.
StandUpGuy
Images: 52
Postby bdosborn » Fri May 27, 2011 8:44 pm
I used one of these:
Works okay for me and has a built in check valve. Google RV water inlet.
Images: 806
Postby kirkman » Fri May 27, 2011 8:52 pm
I have the same one as bdosborn. Works great ! :thumbsup:
kirkman
Images: 55
Postby StandUpGuy » Fri May 27, 2011 9:08 pm
Why do I need a built in check valve?
StandUpGuy
Images: 52
Postby GeoDrop » Fri May 27, 2011 10:00 pm
StandUpGuy wrote:Why do I need a built in check valve?
The check valve keeps the water from running out when you unhook your hose. (I think that is it's purpose) I know many people also install pressure valves to keep the pressure down as some parks have really high water pressure that can cause some pipes to burst. (or so I understand.)
I installed one of these locking ones... although not sure why other than it looks a bit cleaner.
Matthew (& Sandi)
The GeoDrop
GeoDrop
Postby StandUpGuy » Sat May 28, 2011 6:43 am
To keep pipes from bursting? I thought a check valve kept fluids from flowing the opposite direction. So this must be a pressure check then. The pipes in the trailer should not burst from city water pressure.
StandUpGuy
Images: 52
Postby 48Rob » Sat May 28, 2011 7:40 am
Stand up,
A check valve is, as you surmised, to prevent the water from going in the opposite direction.
The water fill valve is part of the water system which is pressurized by city water, or an onboard pump.
When the system is "pressurized" by the onboard pump, the water can leak out of the city water fill port if there is not a cap, plug, or check valve.
As far as city water pressure bursting a trailers plumbing; it shouldn't happen, but it can and sometimes does.
Most trailer systems are rated for 40-50 pounds, some city water systems, especially at certain times of the day can go over a hundred.
Imho, the trailer's system should be able to handle anything a house can...
To answer your initial question, yes, you can use hardware store items.
I used a 1/2" hose faucet.
<img src="http://img.photobucket.com/albums/v284/1948rob/Cabin%20car%20project/faucet.jpg?t=1306586129">
I do however need a special adaptor to use a standard garden hose, since both ends require a female fitting.
I've also seen a standard garden hose run through the floor, left hanging down a few inches under the trailer (with a plug for traveling) that is used to connect to the city water source.
All in all, the RV fill is the easiest way to go.
Some prefer the enclosed lockable fill to keep people from putting something in the pipe, but most get by just fine with the exposed fill.
Rob
48Rob
Postby StandUpGuy » Sat May 28, 2011 8:36 am
48Rob wrote:Stand up,
Rob
Thanks for that Rob, it was very helpful. I think the backflow check valve is used to keep your trailers holding tank from putting potential contaminates back into the city system. I shall have no holding tank so the check valve will be unnecessary in my case it would seem. I do want my inlet to be somewhat flush on the side of the trailer so it may be I need to get an RV inlet.
StandUpGuy
Images: 52
Postby StandUpGuy » Sat May 28, 2011 8:50 am
bdosborn wrote:I used one of these:
I am probably going to break down and buy one of these. It is just bothersome to buy something online for 10 bucks and pay about the same to ship it.
StandUpGuy
Images: 52
Postby bdosborn » Sat May 28, 2011 9:39 am
I got mine at Camping World, if there's one nearby you. It was less then $10.
Images: 806
Postby StandUpGuy » Sat May 28, 2011 5:02 pm
bdosborn wrote:I got mine at Camping World, if there's one nearby you. It was less then $10.
Closest one to me is 50+ miles away, otherwise I would be all over it.
StandUpGuy
Images: 52
Postby madjack » Sun May 29, 2011 8:12 am
...on our first tear, we used one similar to this ebay ckicky ...IIRC, the one we used was all polymer/plastic and was flush mounted along with having a barb fitting for 1.25"ID piping...when opened a standard water hose would fit right into it...we liked it....................
madjack 8)
...that is it under the table.......................mj
Postby StandUpGuy » Mon May 30, 2011 6:34 am
madjack wrote:...on our first tear, we used one similar to this ebay ckicky ...IIRC, the one we used was all polymer/plastic and was flush mounted along with having a barb fitting for 1.25"ID piping...when opened a standard water hose would fit right into it...we liked it....................
madjack 8)
Thats pretty nice. I shall have to do some internet research.
StandUpGuy
Images: 52
Postby madjack » Mon May 30, 2011 9:45 am
SUG...search for "marine water fills" or discount boat/marine supplies...some are quite pricey but IIRC, the one we used was reasonable(10bux?) but it was like 6yrs ago and I am not really sure of price or vendor...sorry, best I can do for ya....................
madjack 8)
