It's Happening
Starting to look like a mini house
Postby Sandy St. Louis » Mon May 30, 2011 11:26 pm
Image Just a note, this picture is taken from the upper level of my home looking down on my acre of good stuff and my wonderland. I like lots of stuff and everything here is usefull or could be, I think. Sandy
Sandy St. Louis
Images: 64
gable end
Postby Sandy St. Louis » Mon May 30, 2011 11:30 pm
Image This is the front gable end framed, sheeted and the loft window cut out
Sandy St. Louis
Images: 64
scaffold
Postby Sandy St. Louis » Mon May 30, 2011 11:34 pm
Image Just have to love scaffolding
Sandy St. Louis
Images: 64
trim begun
Postby Sandy St. Louis » Tue May 31, 2011 12:01 am
Image The background colour has been painted and doing the trim out has begun
Sandy St. Louis
Images: 64
shingling gable end
Postby Sandy St. Louis » Wed Jun 01, 2011 8:15 pm
Image I am trying to put a pattern with ceder shingles to cut the apperance of tall and skinny the porch on some minihouses does this with the sacrifice of trailer floor space.
Sandy St. Louis
Images: 64
Rear gable complete
Postby Sandy St. Louis » Wed Jun 01, 2011 8:27 pm
Image The rear gable is complete except for some trim around the door and the door the end is complete
Sandy St. Louis
Images: 64
Right side
Postby Sandy St. Louis » Wed Jun 01, 2011 8:31 pm
Image The right side is complete trim and battens which cover the seams and make the sheeting become nice looking siding
Sandy St. Louis
Images: 64
The front complete
Postby Sandy St. Louis » Wed Jun 01, 2011 8:34 pm
Image The front is now complete some paint touch up is yet to be done on the whole minihouse
Sandy St. Louis
Images: 64
A few build notes
Postby Sandy St. Louis » Wed Jun 01, 2011 8:45 pm
With a door lockup will be complete. I will have to build the door as a custom one is to pricey. This project has been fun , the building has 15lbs of screws,18 tubes of construction glue, 1/2 a case of 3.5inch nails. over 8000 staples and 20 3/8 x 6 carrige bolts . complete lockup will be in a couple of days. Up until now we 2 over the hill guys have spent about 130 old guys hours in total
Sandy St. Louis
Images: 64
front porch
Postby Sandy St. Louis » Fri Jun 03, 2011 9:51 pm
Thanks Slow, after reading all the other threads on tiny houses I am convinced the advice of not using trailer space for a poor functioning porch is very correct.
Sandy St. Louis
Images: 64
lockup
Postby Sandy St. Louis » Fri Jun 03, 2011 10:00 pm
Sandy St. Louis
Images: 64
van towing minihouse
Postby Sandy St. Louis » Fri Jun 03, 2011 10:02 pm
Sandy St. Louis
Images: 64
Postby droid_ca » Fri Jun 03, 2011 10:07 pm
WOW thats looking really awesome I'm so jealous I want to start on mine soon I thought I had it all worked out then you made it look so easy
Excelent job
can't wait to see whats planned for the inside
:applause: :thumbsup: :applause: :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
tiny house
Postby Sandy St. Louis » Fri Jun 03, 2011 10:11 pm
It's at lockup! The plan now is to regroup and figure the interior and how to best use it. The advice on ship's ladders is a bonus I'm leaning towards the double step using a landing to spread the required space in 2 directions . I must also finish a couple of other projects .Sandy
Sandy St. Louis
Images: 64
Postby Sandy St. Louis » Fri Jun 03, 2011 10:14 pm
Thanks Droid,hope you start and post your build with the amount of research you have done I know it will be great .
Sandy St. Louis
Images: 64
