Structural differences between 4x8 vs 5x8
Postby DiabloCanyon » Tue May 31, 2011 12:40 pm
I am finishing up the skin on my first TD which is a 4 x 8 and it got me thinking that the next time around if I tackle another one, I may do a 5 x 8. I was wondering what the structural differences were with regards to spar placement, extra reinforcements (if any), or do things just remain the same with layout? Is it necessary to upgrade to oak/hardwood for spars to add that extra bit of strength?
Thanks again!
DiabloCanyon
Postby kirkman » Tue May 31, 2011 2:22 pm
I did not make any structural changes when I built my 5x8. 5 years and still looking good! :thumbsup:
kirkman
Images: 55
Postby Mightydog » Tue May 31, 2011 6:16 pm
The only structural changes we made were in the profile. We really didn't make any as a result of going five wide.
Mightydog
Postby dh » Thu Jun 02, 2011 11:43 am
Same here, nothing special, just made it a foot wider.
dh
Postby David S » Fri Jun 03, 2011 4:19 pm
I'm building 5 wide,used yellow pine 2x2 for spars,spacing is tighter on the sharper part of the curves,you mielage may vary. :)
David S
Images: 53
Postby OuttaHand » Sat Jun 04, 2011 7:33 am
I am just finishing up a 5' wide. The biggest thing I can think of is the amount of plywood you'll need.
On your 4', for the roof, were you able to run one sheet wide and use the entire 8' length front-to-rear? If so, you obviously can't do that on a 5' wide. You might be able to find 5' wide plywood, but if you mount your side walls to the outside of the trailer frame rails like I did, that's going to add roughly 1.5 inches to the overall width. That means if you want your roof plywood to lay over top the side walls, you are going to have to use 8' long plywood and lay it sideways.
You can use some of the not-quite-3' long cut-offs when you're working on the interior and galley, but you will probably have a little more waste and expense.
Teardrop newbie but camping "oldster"
OuttaHand
Postby jdaan » Sat Jun 04, 2011 11:01 am
OuttaHand wrote: You might be able to find 5' wide plywood...
5x5 Baltic Birch is great if you can find it in your area. The price is a little higher per square foot than some of the other stuff, but you might make that up in reduced waste.
Justin
Justin
Build Thread: Here
jdaan
Images: 46
