Cliffmeister2000 wrote:I borrowed my sister's TTT in 1980, and towed it behind a Dodge Ram 50 with a bumper ball. About 500 miles from home, I gave everything a once over. The nut on the ball had backed off, though not completely. I had nothing with me to do anything about that. I had to unhook and drive into the nearest town, buy a big wrench to tighten the ball nut, and go back and get the trailer. Now, I carry a big cresent wrench. Have never needed it but that one time I didn't have it.
Engineer Guy wrote:I got some 2,800 lb-rated 'peened' Chain at Home Despot. Holding both ends up, I hung the center down into the A of the Frame, just behind the Coupler. I took both Chain ends and, from behind this hanging-down loop of Chain, fed them through inside from the rear to the front of this loop. I secured the Chain Links there together with an ample-sized Quick Link. I put major-sized Snap Hooks on both Chain ends to attach to the TV. All components are comparably-rated to avoid the proverbial weak link.
The Quick Link snugs everything together and prevents movement w/o welding to the TT Frame. In dicey areas, I can quickly remove this 'multi-function' Chain to secure a Spoke Wheel to the TT Frame and lock/immobilize it.
