@ starleen2...thank you!
@ Steve F.....
I haven't towed loaded much more than 20 miles...but it was rock solid. Part of the design is that the batteries (2-6v 220A/H) and the 21 ga. water tank are located between the hitch and the front of the wheels. Below that is a full size spare. I planned it that way to help offset the rack and the tent (200lbs). The trailer also has a steel 1/8" deck, and even though it's a spring over axle, is extremely solid. My thoughts were to keep the heavier items as low as possible as to keep the center of gravity low.
The water tank filled and the batteries combined are about 320 lbs, and there are also 2 - 5 gal water cans located on the outside. I'm a big believer in lots of tongue weight. Although the nose if filled with light stuff like blankets and sleeping bags, I'm betting I'm sporting in excess 350 lbs tongue weight....which is fine with me. I added the Airlift 1000 bags in rear of the 4Runner, and they seemed to work well also.
@ Norm/mezmo
NORM!!...
Glad you like it! The inside renovations will commence in March, and although sometimes I'm not sure what to do....I defintely know what not to do...lol. I actually have a couple of designs in the works for a new one, but if I don't let the dust settle on this one a bit....I'll be in Divorce Court for the next one...
Now just a few of the systems start. The batteries and water tank are housed in plywood with a removable top. There is a second peice of plywood that is laying flat, along with 3 - 2"x6"s that pull out and form the bed inside the trailer. In the "closed" position it carries 4 large plastic lockers that house the stove, sink, annex, kitchen needs, etc.....all the camping goodies.
Here's the short list of on-board ammeities.
Engel 45 12V fridge....Port-potti(popular with the ladies).....Instant Hot shower hot water heater.....Cabelas 4' x 8' easy up shower/potty tent....31 Gals of water with a 12V pump and quick disconnect fittings for sink and/or shower...2-20# fiberglass tanks with propane tree for propane light and propane 3 burner stove.......10' x 10' First up Canopy with screen/solid walls kits......2 - 6V batteries able to produce 450 A/H of power, backed up by a Honda eu2000i generator if need be......45 Amp Iota Converter......LED task lighting inside and outside, also in tent....54" wide bed inside the camper, same size on top in tent.........8' aluminum fold down kitchen counter.....Shovel and Axe mounted on outside.........Hi-lift to mounted on inside
The fridge...
Here's a shot of the inside, very early on....
