The other big difference is that it is using waterproof glue to hold the plys together so it is not going to seperate like interior rated plywood will with moisture. This is also true for lesser quality exterior rated plywoods. They use the same adhesives as the marine plywood but as previously stated they have no voids and they also have lots of layers, which adds strength.Deryk the Pirate wrote:Yeah I saw that blurb also on wikipedia... but I was hopeing to hear from people who worked with it.
If there are no voids inside of it to hold moisture but if the end grain will still wisk in water its still going to rot right? If you have to encapsulate it in epoxy then is it really worth the price from regular CDX?
Thanks
Deryk
Yes I think paint can do a fine job of it. There are lots of people here on this site with painted trailers. I think your real question you might consider posting is about how effective paint alone can be for protecting a trailer. Frankly if you think about it a trailer is not much different than a house. I think most consideration is for the top. Keeping the water out of the roof is most important. On your build you used a rubber membrane. That coupled with well sealed and painted sides should be pretty good in my opinion.Deryk the Pirate wrote:Thanks Standupguy...so the big difference between marine ply and exterior ply is no voids to hold moisture and more layers for increased strength... too bad it still needs to be encapsulated lol.
I'm on a tight schedule to get lv2 campable for the first week of august. I'm guessin leaning towards useing a mix of paulownia and red and white cedar.
I'm guessing paint alone isn't going to seal marine ply well enough?
