Great Find at Lowe's (Whirlpool Gas 4 Eye Cooktop)
Postby Bandit » Tue Feb 14, 2006 11:28 am
I was just at Lowe's looking for some items for my galley as I would like to have all the items present so when I start building, I can have the items there for fit and dimensioning.
I have been searching for cook units (gas) on the internet, ebay, Cabelas and Bass Pro Shop. But, I was unable to find anything that suited a TD.
I then walked into Lowe's and found this on a clearance table.
It was regularly $399.00 marked to a clearance of $100.00 and then an additional 25% off.
There was a whirlpool model and another GE model.
I grabbed the Whirlpool, because it also have the LP conversion jets with it.
It is a little larger than I anticipated that I would use, but for this price, I will make it fit.
The igniter is 110V, but it states that during a power failure, you can lite it with a match, so I do not know if I'll wire it in. Probably will.
:D :D :D :thumbsup: :applause:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby Chris C » Tue Feb 14, 2006 1:34 pm
Great find! :applause: But how are you planning on baking the bisquits? :thinking: I won't come for dinner without bisquits, no siree!
Chris :D
Chris C
Postby Ira » Tue Feb 14, 2006 2:23 pm
Bandit--what do you mean by the LP conversion jets?
Also, what are the dimensions on it?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Bandit » Tue Feb 14, 2006 2:46 pm
These are setup for home use and Natural Gas. So to use LP or Propane you have to have a conversion kit. Which means smaller jets for the gas to pass through. Your propane regulator controls the volume or pressure, but the jets control how it burns.
The dimensions are 30' wide x 21" deep and 5/8" above the counter surface and 2-5/8" below the counter surface.
I am having to change my layout to accomodate it, but this won't be a big problem.
Bandit
Postby Slayer » Tue Feb 14, 2006 5:19 pm
Bandit. Is there a gas regulator in that unit?
I know its the photographer, and not the camera. I'll keep shooting with a Pentax. Just in case.
Slayer
Postby Bandit » Tue Feb 14, 2006 5:26 pm
No, I will pick a regulator up at Lowe's, or may pull one off an old grill!
Bandit
Postby Bandit » Tue Feb 14, 2006 9:00 pm
As for the Biscuits!
TOASTER OVEN MY MAN!
:lol:
Bandit
Postby Micro469 » Tue Feb 14, 2006 9:27 pm
110 volt igniter? just wire a barbeque igniter to it.. pushbutton, no matches
John
Micro469
Images: 382
Postby Steve_Cox » Tue Feb 14, 2006 10:00 pm
Micro469 wrote:110 volt igniter? just wire a barbeque igniter to it.. pushbutton, no matches
John,
Good idea ! :thumbsup:
I might try that with my Flamineta oven. It has a shutoff valve with a thermo-couple, but has to lit with a match. Thanks.
Steve_Cox
Images: 196
Postby Bandit » Tue Feb 14, 2006 10:33 pm
I'll have to take a look at this option.
The current ignitor provides a spark to all eye's. I don't know if the barbeque ignitor will be strong enough to provide a spark to all the eye's at once.
Obviously, the only one that lights is the one that has its gas on.
Thanks,
Bandit
Postby bledsoe3 » Wed Feb 15, 2006 5:59 am
My grill has a battery operated igniter. It uses a 9v battery and when pushed it sends a spark to the main burner, side burner and the rotisserie at the same time. It also keeps sending a spark until the button is released. The old style had to be pressed over and over (one spark per press).
Try here. http://www.allpartsgrills.com/item541969.ctlg
bledsoe3
Images: 112
