Great writeup on a 'glass over foam trailer.
http://www.goldbrand.info/motorcykelhusvagn2.html
Volund wrote:...and what the total weight is?
stomperxj wrote:Volund wrote:...and what the total weight is?
319lbs according to the text at the top of the page...
Volund wrote:stomperxj wrote:Volund wrote:...and what the total weight is?
yeah, apparently I can't read....
Thanks![]()
Foam and fiberglass looks like an awesome solution for a small car.... like my Rabbit
swampjeep wrote:heck, I think my jeep is 2x the power and weight of a rabbit, but I think teh foam build will be a good route for me.
Wobbly Wheels wrote:Thanks Stomper , this is exactly what I was looking for !
I am working out a glass-over-foam popup a la the Compact design (with a few twists of course...).
That post was just what I'm looking to do, right down to the same resin used, lol. will also be running the shell right up the bridle, but it'll be interior space rather covered exterior storage - that will probably be the head.
Part of foam's appeal for me is that I can keep the suspension loads light enough to drag it through cross ditches and waterbars and still be able to pull it up a chattering washboard with my 4 cyl truck. How have you found yours to be as far as stiffness and robustness on rough roads (even though yours isn't foam)?
Did you have to make a compromise on Sawtooth between ground clearance and ease of access or do you just use as a step to get in and out after building it to the same height as your XJ?
