eamarquardt wrote:Batteries are constructed differently for different purposes. Starting batteries are designed to provide very high current for short periods of time (so they have lots of plates and a lot of surface area). At the other end of the spectrum there are deep discharge batteries that are designed to provide much lower currents for extended periods of time (fewer but much thicker plates). There are "compromise" batteries with characteristics in between the two extremes.
"Marine" batteries are kinda in the middle and will tolerate a discharge of 50% of their rated capacity repeatedly. Golf cart batteries are much more robust and can tolerate up to an 80% discharge of their rated capacity w/o degraded service. So, for good service in a trailer a starting battery is a bad choice. Marine batteries are moderately sized and priced and can be a reasonable compromise. A true deep cycle is gonna be bigger, heavier, but provide more capacity and a longer life.
"Choose wisely".
Hope this helps.
Cheers,
Gus
Where does the cheap little lawn tractor batteries fall? They are used for starting small engines, but are left to discharge for sometimes weeks or even months. Are they some type of deep cycle?
The reason I ask is I would like a very light battery for my Ultralight build. My needs would just be LED lights and a Fantastic fan. If the Fantastic is too much draw, I would try computer fans instead. Weekend use only or charge from vehicle while traveling.
Any thoughts/issues with this idea?
