Boanerges4 wrote:I was wondering if anyone has ever used HENRYS asphalt emulsion from Home Depot to seal bottom side of floor.
I did two coats of the 25/75 mixture and then the Henrys black goo. I suspect anything that is put on will be a benefit.Wolffarmer wrote:After much thinkin and rumination I have decided that on my next build there will be no "black goo". I am going to cut some spar varnish with mineral spirits, 50/50 and give it at least 2 coats with that and then with the full strength spar varnish.
The only reason I can see that we use the black goo is cause it makes the bottom of the trailers black like the manufactured RVs.
Just my thoughts
Oh, and the Henry's stuff is pretty good if you go the "black goo" route. I have used it on other projects. like roofs and leaking cement walls. Things it was made for.
Randy
Users browsing this forum: Bing [Bot], matphat and 9 guests
