by 48Rob » Mon Jun 20, 2011 6:52 pm
In general no, dumping gray water on the ground is either a major offense that can get you a fine and removed from the campground, or is frowned upon by other campers because they are the ones who will be "camping" in the mudhole you leave behind.
That said, there are some places/situations where running a 25' long garden hose over a ravine, cliff, into the woods, etc, may be a realistic way to dispose of gray water without causing harm.
You really should have a small holding tank for those times when it is required.
If careful, 1 (average) person can shower with 3-4 gallons of water.
A 10 gallon holding tank would be reasonable for a couple.
A portable tote tank is also a good less expensive option than a built in tank.
Rob
