oil canning!
oil canning!
Postby Burro » Mon Jun 20, 2011 12:34 am
So I am nearing the end of my project and today I pushed the teardrop out into the sun and I noticed that one side of my aluminum has started to "warbl" in the hot sun. I used staples along the edges and I used lifetime caulk around the edges and in the larger areas to help hold it to the plywood when I built the trailer. The last 1/3 of the aluminum on 1 side seems to be warping in the sun. What the heck should I do?!!!! removing the staples is really not an option. I noticed this evening when things cooled down that it was fine, but in the hot sun it warps, will this cause any damage? Has anyone else had this problem? I was thinking maybe of running some waist trim or simply some screws into the aluminum to keep it from warping and bubbling out.
Any ideas?
Thanks,
Burro
Postby madjack » Mon Jun 20, 2011 1:05 am
I would say...LEAVE IT ALONE...nothing you can do will "fixit" and it should settle out on it's own...at least that was my experience on our first tear...................
madjack 8)
Postby aggie79 » Mon Jun 20, 2011 6:17 am
Our teardrop aluminum oil cans in the heat too, but it always goes back when it cools down. I don't worry about it.
Postby Burro » Tue Jun 21, 2011 1:18 am
Thanks, Glad to know it won't be a big eye sore, and it won't crease.
Burro
Postby Rudyjr » Tue Jun 21, 2011 4:37 pm
This a topic that I have wondered about while looking at the builds that incorporate an aluminum skin. I have seen people who used a perimeter bond method and those that used a contact type cement over the entire surface. I am curious as to which way produces less oil canning effect when the sun hits it, or is it pretty much the same no matter what?
Rudyjr
Postby emiller » Tue Jun 21, 2011 6:27 pm
Not all aluminum skin tears oil can. Mine doesn't, but is steel framed with a lot of rivets.
emiller
Images: 157
Postby CARS » Tue Jun 21, 2011 11:12 pm
This is just a theory...
I use heat from a torch to heat a "high spot" or stretched metal and then quench it with a wet rag to shrink the stretched metal. Heat expands the metal but cooling it quickly draws the molecules together.
Maybe overtime when you see it expanding in the sun, take a cold, wet rag and see if you can shrink the skin.
If nothing else, it gives you something to do! ;)
Chris'
Autobody
Restoration
Service
CARS
