High Desert wrote:OK Thomas, I found the one I was thinking of for a little more inspiration![]()
http://www.tnttt.com/viewtopic.php?t=27647&highlight=vardo+camper
Yeah, that's it - That's the sort of thing I was talkin' about!
AL
proformance wrote:Did some more searching and came up with the adds I was referring to. the add was actually on OODLE.
Here is the TD Camper Shell
2bits wrote:proformance wrote:Did some more searching and came up with the adds I was referring to. the add was actually on OODLE.
Wow, that is pretty much it, even has the three lines on the side, but the side doors are about useless, and it looks a little awkward for some reason to me. Maybe the height? Maybe nix the side doors so it can sink down into the bed as it should...
Amazing that you found this!
proformance wrote:2-Bits,
I have been to another website this gentleman has created which included pics of the Airstream/Sprinter (similar to the Canned Ham/Sprinter.) If I recall correctly, he mentions the base of the Teardrop camper has a fold down tailgate (below the rear hatch) similar to a conventional truck tailgate. This tailgate provides access to the original truck bed storage area.
Here are some options/ideas you may consider.
1) Eliminate the two side doors and replace with windows (slider or tilt.)
2) Use the rear hatch as access to the TD sleeping area.
3) Instead of having a single tailgate, split the tailgate (street-side/curb-side.)
4) Incorporate into the Street-side half of the truck bed/tailgate, a full length sliding drawer/compartment incorporating full kitchen amenities (similar concept to kitchen set-ups used in many of the Aussie Outback Trailers.)
5) On the Curb-side, create a full length sliding storage drawer on the lower half of the opening/tailgate with a telescoping drop ladder storage compartment immediately above the storage drawer. (Create a slide or catch for the ladder so the ladder remains attached to the TD Shell.)
With this set-up, you will halve a full size TD hatch to access the interior of the TD, full kitchen amenities, extensive storage area and an attached telescoping ladder.
(Hopefully my concept come through in the above.)
Alfred wrote:Hey Y'all,
I came across this picture, too. I can't link it into the post because it is a bmp photo. It is a little house in the back of a pick-up truck.
http://thatwentwell.net/blogfiles/wp-co ... camper.bmp
AL
