Room for tires
Room for tires
Postby Deryk the Pirate » Wed Jun 22, 2011 7:42 am
How much space should I keep between the tire and the sidewalls?
Deryk the Pirate
Images: 158
Postby aggie79 » Wed Jun 22, 2011 9:15 am
That's almost like asking if CPES is good or not.
Opinions are all over the map. Some of the differences are due to what type of axle you have - torsion or leaf-sprung. With leaf springs, there is a chance for more camber of the wheel/tire, so you need more room. With a torsion axle, there is very little camber, so you can get away with less clearance. I have heard that as the rubber in torsion axles age, and with use, it can result in negative camber.
I have 3/4" between the sidewall and tire - I'm using a torsion axle - and that has worked fine (so far). My tires are extra-wide, and if camber comes into play, I can go to a less wide tire.
Take care,
Postby Deryk the Pirate » Wed Jun 22, 2011 9:32 am
Hey Tom, I have a leaf spring's on my longer axle, and was just wondering how close I can get without wearing out my standard HF 12" tires lol. I think Ive got about 2" right now.
Deryk the Pirate
Images: 158
Postby madjack » Wed Jun 22, 2011 9:45 am
2"s is gobs and plenty...I use the "knuckle" rule...if you can push your hand, upto the knuckles between wall and tire, you should be golden..between 1-1.5"s.....
madjack 8)
Postby Mightydog » Wed Jun 22, 2011 11:11 am
madjack wrote:I use the "knuckle" rule..between 1-1.5"s.....
**whew**
I'm never going to get in a bare knuckle fight with you!
Mightydog
Postby absolutsnwbrdr » Wed Jun 22, 2011 11:33 am
A knuckle?! :shock:
Mine may be a little close. :thinking:
My 3/4" sides sit against the outside face of the trailer frame rails, so my clearance is pretty tight. When I finished the trailer, I knew that it was close (~3/16") but when I went to repack the bearings this Spring, I realized that the one side has actually rubbed a little.
The trailer saw well over 2k miles since its completion last Spring, and the tire doesn't show any wear on the sidewall so I'm just gonna keep on truckin.
I know... its not ideal, but so far so good.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Dale M. » Wed Jun 22, 2011 2:00 pm
I have 2 inches between bulge of tire and frame....
Dale
Dale M.
Images: 18
Postby dh » Wed Jun 22, 2011 9:05 pm
absolutsnwbrdr wrote:A knuckle?! :shock:
dh
