New Foamie Hybrid build * Frame Finally Done! *
Postby DJT » Sun Jun 19, 2011 11:20 pm
So waiting around the house tonight for a friend to show up. Thought to update the plans:
New windows, and deleted the tongue box.
And the new idea instead of the galley, a bunk bed (a la Eagle!). Also moved the bed back to make room for a wet/muddy doggie!
DJT
Postby GPW » Mon Jun 20, 2011 5:33 am
Gotta' make room for the dog !!!! Nice drawings DJ !!! :thumbsup:
Postby eaglesdare » Mon Jun 20, 2011 6:01 am
that'll work for me :thumbsup:
Louella
May the foam be with you.
eaglesdare
Postby DJT » Sun Jun 26, 2011 1:10 pm
So, this week "off" wasn't as productive as I had hoped, an 11 month old has other ideas!
Did manage to get the sub floor framing tacked together:
and fully welded:
Out less than 1/16" over 8'! not bad for single handed with a couple of ratchet straps!
Got the temp coupler done up as well, and the axle mounted. Just need to mount some tires and put in some gussets and I can roll her out and clean the shop! :applause: Then it's time to actually start on the Foam!
DJT
Postby GPW » Sun Jun 26, 2011 6:37 pm
DJ, Awesome welding job !!! 8) 8) 8) 1/16" is pretty Darn GOOD !!! :thumbsup:
Postby DJT » Fri Jul 22, 2011 2:23 am
Well, it's been almost a month, and I haven't gotten as much accomplished as I'd hoped, but at least the last couple of days have been productive!
Got the skirt mostly mounted, and all the other pieces at least cut and fitted! Also got the tires/wheels mounted. These weren't plan A, but they ended up being free!
Oh, and since they weren't the original plan....
They don't fit! Oh, well new axle on it's way...so much for thrifty!
Something got messed with the ride height with that tire/wheel combo as well:
26"? Really?
Some heavy metal:
and my "entry step" which is currently 27" off the ground!
DJT
Postby GPW » Fri Jul 22, 2011 6:56 am
Looking GOOD DJ !!! STOUT!!! :thumbsup: 27" does seem like a Big step ... :o You thinking about some fold out steps ???
Postby eaglesdare » Fri Jul 22, 2011 7:01 am
is your shop a/c'd? i can't imagine doing that kind of work in this kind of heat.
it is looking good. tall, but good. :applause:
Louella
eaglesdare
Postby DJT » Fri Jul 22, 2011 9:00 pm
Eagle, it was only 41* (106*) yesterday. It cooled off after midnight though!
GPW, I think I'm going to flip the axle, and add some kind of stairs.
DJT
Postby jhanlon » Sat Jul 23, 2011 12:22 am
DJT wrote:Eagle, it was only 41* (106*) yesterday. It cooled off after midnight though!
I've got a similar problem with my 48 X 41 HF trailer and my van.
G20 Chevy van - lifted prerunner suspension - center of trailer ball is at 24 " and lower van door sill is 29 inches. New meaning to 'Hop In'
Lower the van back down or raise the trailer on bigger wheels and tires.
Let us know if you find some inexpensive single steps. Fold up or even fixed.
John The Vanner
John the Vanner - now with 41 X 48 HF trailer
jhanlon
Postby GPW » Sat Jul 23, 2011 5:47 am
DJT, I recall you saying you need this for off road .... maybe you need the clearance , depending where you go ? ... How about a pull out RV step kinda' thing??? that would help huh ... ?
Postby DJT » Sat Jul 23, 2011 6:56 am
Funny thing is, I can't seem to justify the expense of the things from the RV supply (even though the budget for this is pretty mug shot as is!). I guess I'll have to scout out the wreckers... A friend suggested looking at big rig/tractor steps?
DJT
Postby GPW » Sat Jul 23, 2011 7:11 am
DJ , schmaybe' just weld something up ...??? How about a small fixed step ... or something that would flip down ... like the passenger trains use ??? :thinking: Image
Postby wagondude » Sun Jul 24, 2011 10:54 am
When I was young, a neighbor had a pickup with a slide in camper. There was a flip down step bolted to the step section of the rear bumper. I really don't remember what it looked like, but when it was folded, the top surface of the step rested on the step of the bumper in such a way as to not obstruct the license plate.
Bill
Bill
101137
wagondude
Images: 35
Postby DJT » Mon Jul 25, 2011 9:46 am
Interesting ideas! I wonder if I could do a fold up step into the footwell? Then maybe just a step stool on the ground? I might be over thinking this! K.I.S.S. right?
DJT
