Help needed on TV install
Postby akula1 » Wed Jun 29, 2011 7:44 am
Hi all, I am not a wood working guru and need technical help.
I just got my Little Guy Silver Shadow, and I have a under counter LCD TV I want to mount to the ceiling. It only weights 6lbs. The screws only come in from the top down. That makes it hard to install
I contacted Little Guy, and they told me that there are 2X2 supports are 6" apart by the ceiling vent, and one 6" back. My thoughts are to take two strips of 2X1 birch ply wood, and attach them to the TV lengthwise to where they extend past the edge of the TV, and screw the front into the 2X2 at the back of the ceiling vent, and the back flush mounted against the cabinet.
Does this sound good, or does anyone have any ideas? Pictures would help a lot.
Thank you,
John
John Serenita
Owner of a 7 X 14 Cargo Camper
akula1
Postby droid_ca » Wed Jun 29, 2011 9:07 am
would an industrial two sided tape work thats what I use on the flip down in my car
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Woodbutcher » Wed Jun 29, 2011 12:02 pm
Yes John. That would be a good way to do it. I may use a single piece of 1/2" plywood instead of the strips. It could even be wrapped with some fabric before screwing it to the ceiling. Something that would match or blend with whatever the trailer ceiling is.
Woodbutcher
Postby planovet » Wed Jun 29, 2011 2:23 pm
Woodbutcher wrote:Yes John. That would be a good way to do it. I may use a single piece of 1/2" plywood instead of the strips. It could even be wrapped with some fabric before screwing it to the ceiling. Something that would match or blend with whatever the trailer ceiling is.
That's what I would do :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby akula1 » Wed Jun 29, 2011 5:10 pm
Droid, I like your idea, but in Arizona where it gets extremely hot in vehicles the glue doesn't give, but it does slip and slide and makes a mess.
I was thinking of doing the strips because I have a 5"X16" of solid birch I could split and use to match the interior.
I will hopefully have my install done and I can post pictures.
Happy trails to all this weekend.
John Serenita
akula1
Postby droid_ca » Wed Jun 29, 2011 9:12 pm
the stuff I used is
http://www.shop3m.com/70016041199.html
works great I did a couple of strips as well as the mounting scews if it comes off I have other issues to worry about
“Fide Canem”
droid_ca
Images: 176
Postby Dale M. » Thu Jun 30, 2011 10:27 am
If you use tape.... Be sure there is padding below it when you tow....
Dale
Dale M.
Images: 18
