Ok next I turned my attention to the doors. I had saved my door 'blanks' from when I cut the openings in the side walls. I built them up just like the side walls with spars and rigid foam insulation. I guess I was in a hurry because I don't have any pics!!
I did get some pics of cutting out the opening for the windows. I simply traced the trim ring where I wanted to place the cuts. Placement was more complicated that I expected because I also needed to account for the hinge and latch hardware. That is why the opening is NOT centered in the door.
