Interior Lights - Incandescant, LED, or Flourescent
LED draw
Postby Crazylegs » Thu Jun 16, 2011 12:31 am
I did some testing with LED vs Incandescent 1157 bulbs.
No load. Image
1 Incandescent 1157.Image recovered. Image
1 LED 1157Image Image
Crazylegs
Images: 72
Postby pete42 » Thu Jun 16, 2011 6:30 am
.52 volts vs .09 volt drop doesn't look like much but I'll bet it would add up over time.
I haven't done any real boondocking just the occasional overnight in a rest stop or campground when I either couldn't hook up to electricity or I didn't want to.
but to someone who regularly does live off the grid seems to me would make a difference.
Pete
pete42
Postby vtx1029 » Thu Jun 16, 2011 6:34 am
woytovich wrote:
vtx1029 wrote:I used these as under cabinet lights in our new kitchen and they rock! I run 8 strips in combination with a PWM dimmer and rarely have them all the way turned up. But it could still be costly out fitting a whole trailer with them.
http://www.dealextreme.com/p/36-led-576-lumen-string-light-with-aluminum-alloy-shell-warm-white-light-12v-47300
I just ordered 2 strips... we'll see how they work in my little 5x8...
FYI you can cut the strips every 3 LED's making them shorter or connecting them with another strip ;)
vtx1029
Images: 70
Postby Pyrofish » Thu Jun 16, 2011 10:05 am
Just bought 5 of these.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190360491161&viewitem=&sspagename=STRK%3AMEWNX%3AIT
I'll look at LED bulbs for them once I have them installed. I don't plan on camping sans shore power until next spring anyway. So I have time to play with it. Thanks for all the help. I'll probably be buying some of the other recommendations for other areas of the Toy Hauler too. :thumbsup:
Pyrofish
Images: 14
Postby Jeffmo63 » Tue Jun 21, 2011 11:45 pm
I think you will be happy with what you purchased. I've worked with the same folks before and am very satisfied. I have 3 duals down the center and 2 singles up front. The illuminate the interior very nicely.
Jeff
Jeffmo63
Images: 81
Postby OverTheTopCargoTrailer » Tue Jul 05, 2011 10:53 pm
Go to mostly Lowes and some Home depot, they have great LED lights, the one in the middle of the picture lights my 7 x 16 very bright with 2 lights $10 each, no wiring, the double or triple AA batteries last up to 50 hours. Just stick them anywhere & never burn your trailer down.
:icedtea: :icedtea:
Postby GPW » Fri Jul 08, 2011 7:14 am
Voltage measurements don't tell much ..... It's the Amps that the lights draw that means something ... Try that and you'll see a BIG difference ... LEDs draw Much Less current (amps) that other types of lighting ...
Postby pete42 » Fri Jul 08, 2011 8:53 am
Just to follow up on what GPW said check out this site http://www.ledtrailerlights.com/tips.htm for trailer marker lights.
the L.E.D. s will come down a regular 1141 cost 49 cents it will be a while before L.E.D. s approach that price
But just like I said when I worked in a service station back in the 1950's when gas went to 24.9 I said that won't last long, fast forward 53 years and I was right :cry:
pete42
Re: Interior Lights - Incandescant, LED, or Flourescent
Postby Pyrofish » Mon Mar 19, 2012 8:42 am
I know this an old thread, but I just now getting around to installing my LED arrays in the incandescent fixtures.
These are the arrays I bought:
http://www.ledtrailerlights.com/rv/RV-1141.htm
I put them in the standard double dome I picked up on ebay here:
http://www.ebay.com/itm/190360491161?item=190360491161&viewitem=&sspagename=STRK:MEWNX:IT&vxp=mtr
This will be my first trip off shore power so I figured I'd better try it out. Wow! I am impressed! These things are brighter than the incandescents that were in there. So much so, that I only need one in each double dome. :thumbsup:
The light isn't as soft as the incandescent but it is definitely as white. I might play with scratching up the lenses with a scouring pad to soften it.
I used an IR grill thermometer to check my installed Incandescent dome lights. They were running 140F. The LED arrays run at maybe a degree or 2 above room temp. Pretty awesome reduction in heat. Just messing around with the temp sensor, I checked the temp on the wire connections on the back of the light switch. The 2 switches running the LED's were 72F. The switch connection running the one set of incandescents left, was at 78F.
Pyrofish
Images: 14
Postby Sevo » Fri Mar 23, 2012 11:25 am
Great thread and info, thank you :beer:
If you are looking to buy more than one this is a better deal, you really save on the shipping... its for a 4 pack of the same dome lights from the same seller.
http://www.ebay.com/itm/4-pack-RV-light ... e3&vxp=mtr
I will use 3 in the cabin and one in the bathroom
Chris
Chris L.
http://www.NAFEX.net
The North American Falconers Exchange
Sevo
Postby Pyrofish » Mon Mar 26, 2012 9:13 am
I used 5 double dome lights in mine. Currently only 4 LED arrays, but that's all I need. Those things are kind of bright. I had several people look in on the build and this is the first time they had seen the LED arrays. All were impressed with the brightness, and whiteness of the light. Several asked for the website and are planning to buy them for they're trailers, and one for the boat he lives on. So I guess what I'm saying, they're expensive at $15/each, but they're worth it so far :D
Pyrofish
Images: 14
