shore power
Anything electric, AC or DC
shore power
Postby Boanerges4 » Sun Jul 10, 2011 8:09 pm
I know this ?? has been asked before but, what kind of amperage does a normal hookup at campground have. You see everything from teardrops to full size motorhomes at these campgrounds, so Im assuming the hookups will handle most anything??
Boanerges4
Postby Miriam C. » Sun Jul 10, 2011 8:20 pm
:thumbsup: You are correct and most campgrounds can do it all... 8)
Postby 8ball_99 » Sun Jul 10, 2011 8:39 pm
Most all campgrounds have 30amp plugs.. A lot of 50 amp plugs also but those tend to be the larger pull through camp sites.. Also most have a standard 20amp plug beside the 30 and or 50.. So yeah pretty much anything. Even a 40 foot camper can plug into a 110v 20 amp plug.. He might only be able to run his AC though..
8ball_99
Postby dh » Mon Jul 11, 2011 1:39 am
Expect to see a 30amp RV plug, Nd a 15amp duplex plug. You may come accross a 50amp plug, but expect to pay more for the sight. If you go with 30amp on the tear, carry a 15amp adapter, and if ya go with 30amp carry a 15amp adapter. Plugging into a standard 15 apm plug can be helpfull, and you might find a 15 amp plug with bad mojo, and need to use te 30 amp.
dh
Postby madjack » Mon Jul 11, 2011 5:58 am
dh wrote:Expect to see a 30amp RV plug, Nd a 15amp duplex plug. You may come accross a 50amp plug, but expect to pay more for the sight. If you go with 30amp on the tear, carry a 15amp adapter, and if ya go with 30amp carry a 15amp adapter. Plugging into a standard 15 apm plug can be helpfull, and you might find a 15 amp plug with bad mojo, and need to use te 30 amp.
...let me give a double ++1 on the adapters...they can usually be found at most box and sporting goods outlets for under 10bux...if you're wired for 15/20amp service, get a 30amp adapter for your cord and if wired for 30amp service get the 15/20amp adapter...........
madjack 8)
p.s. 15/20amp is the same as standard household duplex receptacles..........mj
Return to Electrical Secrets
